Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 06-01-2005, 01:29 AM
  #871
Matt Howard's Avatar
just got a vsf-1 and was going over the settings and I have one question. What exactly is the "power save voltage" setting? It sounds like the voltage cutoff at which the esc will stop supplying voltage to the motor to maintain steering but the instructions aren't very clear on this.
Matt Howard is offline
Old 06-01-2005, 01:31 AM
  #872
centax error!'s Avatar
Originally Posted by F. Alonso
Does anybody have a copy of the Adapter Controller thing's manual available electronically in english?? We were only given 1 manual with ours and its in Japanese.
..there you go! enjoy
File Type: pdf
centax error! is offline
Old 06-01-2005, 01:36 AM
  #873
Hebiki's Avatar
Trader Rating: 26 (100%+)
when you run out of the juice... the esc will save some voltage so you can steer your car out of the way. this is the setting for that
btw.. did you pick up the masami edition? some people are curious about the profile thats in there. maybe you can post it when you have a chance?
Hebiki is offline
Old 06-01-2005, 01:39 AM
  #874
It's quite the opposite on what was said on my manual-
The Power Save Voltage: The BEC output is set and the voltage in which the BEC is set to four stages. A steady voltage to the last minute running is maintained. This is significantly effective to the category that uses four cell with low voltage.
Old 06-01-2005, 02:01 AM
  #875
I didn't get the masami version yet, I was able to pick up a regular VSF-1 and the handheld adaptor for cheap so I went with that. I will be getting either the masami or rayspeed version vsf-1 hopefully in the next couple of weeks.
Old 06-01-2005, 02:55 AM
  #876
F. Alonso's Avatar
You're a champion! Thanks!
F. Alonso is offline
Old 06-01-2005, 10:49 AM
  #877
Regional Moderator
daniz24's Avatar
Masami VFS Profile
File Type: txt
Masami VFS Profile.kpd.txt (478 Bytes, 224 views)
daniz24 is offline
Old 06-01-2005, 12:43 PM
  #878
WHAT THE ....... HECK!
Whats he done to the Servo/Power Cap?
Either i've missed something, or someone is driving without any steering in there car
Someone put me out of my misary and explain whats going on in that pic
Loving it eitherway!
Chears for the Profile, dont do Mod but by chance will be doing the Mod Nationals this week over here, so it'll come in handy im sure
PaulC2K is offline
Old 06-01-2005, 05:29 PM
  #879
berger's Avatar
Silly paula, im guessing its a small much more capacitor as if you notice it plugs into the reciever, so i think its just shoo gloo'd to the top of the servo and then the VFS 1 cap is by the speedo.... He is only running a single diode on his speedo though, maybe someone should point this out to him (Not me)
berger is offline
Old 06-01-2005, 08:05 PM
  #880
Regional Moderator
daniz24's Avatar
Loving it eitherway!)
Hehe.. But I'm afraid I don't get what you meant?
daniz24 is offline
Old 06-01-2005, 08:15 PM
  #881
=MisFitz= NuKe's Avatar
Alright, the cap on the servo is plugged into the receiver to help keep the servo working. By that I mean that when you run very low-turn, very high AMP draw motors, when you punch it, sometimes the motor will draw so much from the batteries (when it spikes) that the speed control doesn't save enough energy to power the servo motor, and you get what seems to be a glitch every time you come out of a corner. I used to do this with the old speed control. The only reason I don't do this with the new speed control is because the guys around here got bored of being beaten in mod....so now they get beat in 19turn
-Mike Patterson
P.S. If I am mistaken about all of this....then I too am utterly confused.
=MisFitz= NuKe is offline
Old 06-01-2005, 09:38 PM
  #882
F. Alonso's Avatar
Yeh, I originally was amazed to see that picture, but its just a really short but wide capacitor that has been stuck to the top of the servo, looking like its a tall capacitor thats inside the servo.
Old 06-06-2005, 11:31 AM
  #883
RBLove is right. call him up for help
for stock... try this setting...
5 <--- starting point for throttle curve
5
4
4
4
4
4
4
3
3
3
3
3
3
2
1 <--- throttle half way pressed (stage #16)
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17 <--- throttle fully pressed. white knuckle and all
enjoy!
Hebiki your the VFS king!
I tried this setting, it's awesome. I wanted a little more top end. So Roger, kicked up 2-3 more after stage 16. The car was fast, finished 3rd overall in a field mixed with both expert and sportsman stock driver. After the main to pick up the cars off the track, you can smell my motor burning! I was geared 7.05, Monster Stock motor, 3600 batteries. And the track layout was flowing and fast.
NorCal_Big_L is offline
Old 06-06-2005, 12:31 PM
  #884
berger's Avatar
I find you need to let the throttle in a little slower, i have to admit in the heat of it all i throttle jam a touch, but provided you dont then it should be okay.. Were the brushes discoloured or was the motor just really hot? As long as it doesnt fade over the 5 minutes i dont worry too much about the motor temp now!
berger is offline
Old 06-06-2005, 12:58 PM
  #885
Pro Models's Avatar
Hey Guys!!
Anybody knows any profiles used at the Reedy Race with 7turn motors?
Bye !!
Pro Models is offline
