Ko Propo VFS-1 ESC
#736
i got a new masami model vfs1 esc and last weekend at the nationals i was able to make great laps. with the help of my esc i was able to set fastest laptimes during the mains and i am really happy with it.
NOW comming back from the nationals i barely can make 5 minutes using my 3800 packs. i dont know what to do. i have been using all the same equiptment (charger motors gearing servo RX) is there something wrong with my esc? i tried cyling my batts and the runtime at 30amps discharge is 7 mins.
tom i will try re-programming it.
any help would be great.
#737
I think different track layout, size, grip and also temperature will cause different ampere draw from motor to batteries.
#738
#739
i....
i have ordered the dual ones but i have the novak super schottky diode in stock and i was wondering if i could use this while waiting for my order to come in.
i....
recently picked up a NIB Hara Twister V2 off ebay for a bargain price of $125.00
#740
raise your profile 5-7 stages..and you should make run time easily. also check your gearing.
#741
Trader Rating: 50 (100%+)
Diode Question
Chris,
Question which diode should I use on my VFS-1 while running a 8 or 9 double.
Also can you give a good Starting point on a profile while using either Mod Motor.
Any help would be greatly appreciated.
#742
Low turn motors
For anything 15T or lower it is recommended to use the Ultimate Shotki Diode Double #45516. Using the supplied Single will not be enogh for low turn motors. Try the Hara setting from the world's. Its a good starting point.
-Robert
-Robert
#743
i now installed my novak super diode and will be running tonight i will keep you guys posted.
thanks for the info
thanks for the info
#744
Re: Low turn motors
-Robert
-Robert
#745
Re: Re: Low turn motors
Originally posted by Kenneth Tan
Is having a Single and a Double wired in parallel overkill?
#747
Originally posted by rc-zombies
instead of the motor...can the diode be soldered to the ESC itself?
I think I've seen this done on one of Hara's cars....
Here is how I did mine...
#749
power switch
does anyone know where can i buy a replacement swtich/switch case for my VFS-1?
my switch was damaged after a big crash. It's still working, but it's case is almost completely destroyed and for sure it can't take anymore punishment. I've tried my local shop, oversea websites and every place i know that sells KO stuff but none of them can get me a replamcent switch or switch case. The only thing i was told i can do is to send my ESC back to KO and get it "fixed". I don't want to do it as this is the only ESC i got and i don't want to without any ESC for a few weeks or even months time
Anyone can help me?
Anyone can help me?
