Ko Propo VFS-1 ESC
#691
Originally posted by Hebiki
by the way.. visit the Ko site.. has a few mod profiles.
#693
Originally posted by kylehirano
Do you know if the new Yokomo based Ko-Propo speed controls are programable?
#697
Can I use the VFS 2000 handheld with a VFS-1 esc? When adusting do I have to unplug the battery wires to the batt or use the batts for esc power?
#698
you will need to use the battery to power on the ESC. the hand held device is powered by 4 AAA batteries. unsolder your motor for safety precautions.
#699
Thanks Hebiki. u d man!
#701
Originally posted by F. Alonso
What safety issues could occur with the motor installed?? I have not had a problem as yet... but I don't want to have a problem. I just didn't see that detail.
#703
Only problem i could see would be the motor/car moving if something was triggered which shouldnt happen under normal circumstances, popping a brush out could save the hassles of it legging it off with your adapter hanging on for dear life
Ive only used mine twice, with a setting Karl/Berger gave me, not sure if its one from the site or one you'd recommended to him Hebiki, but ive been very impressed with the performance of it so far. Ive had Novaks for a good few years which ive always liked and just ditched a Nosram Dom Evo (QC2) as i wasnt that impressed with it and the hype surrounding anything LRP have touched, and wanted to try this esc which isnt really available in the UK that i know of (why this is i dont know, maybe im wrong but you just dont hear of it over here yet radios & servos are fine).
Ive not had the time to play with settings to see the differences on the track, ive only ran it in a high end stock setting, but from that i have to say the ESC is very good, nice and compact (ideal when its going into the narrowest TC chassis on the market!) and goes like a rocket.
Cant wait to try it in the B4 sometime soon, first attempt i hadnt set it up for the TX and left the instructions at home, cue much messing and the quick installation of a mates Nos Dom Evo! Ooops hehe
Karl:
........ your a whore
and a traitorous one at that!
Buy an FK05 and all is forgiven
Karl:
#704
Note to self:
Press 'edit' not 'quote' to make changes to your own posts!
#705
Originally posted by Speedo
I've been having trouble recently running Ti's with my VSF-1 Pro. I have not been able to finish a run without loosing power. Sometimes it will come back on after a few seconds and go for another few laps before shutting off again, sometimes not. Could this be due to not running a shottki (sp?) diode on the motor, or the settings I've programmed the ESC with? I used the settings for a technical track using a mod motor from KO's website.
I've been running 10x1 Ti's, without any shottki diodes. I've heard that using a diode makes the motor feel like it has drag brake, which I don't really want.
Josh
Josh
You have experienced this issue, I am interested to know how you have resolved it.
I run modified motors with the setting for technical track and the speedo loses power and shuts off. This is very annoying
I think it is a thermal protection but when I touch the esc, it is warm...
Maybe, KO Staff can also enlighten and give advice ?
thanks in advance,
