Old 03-30-2005, 11:19 PM   #676
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally posted by Hebiki
RBLove is right. call him up for help
for stock... try this setting...
5 <--- starting point for throttle curve
5
4
4
4
4
4
4
3
3
3
3
3
3
2
1 <--- throttle half way pressed (stage #16)
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17 <--- throttle fully pressed. white knuckle and all
enjoy!
Hebiki, I am going to give this setting a try. Does it feel punchy or is it a smoother feel? I am assuming punchy since the drive freq starts out so low.
Jones, Sorry I couldn't talk last night. Things here at work were a little crazy.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 03-30-2005, 11:22 PM   #677
RBLove's Avatar
Power save is factory set at 3.0v. You will want to leave this setting as is unless you are running a receiver pack. It is the BEC.
Heibiki or KO Staff can explain in more detail.
Old 03-30-2005, 11:32 PM   #678
no problem Rob. ...I understand. Cant wait to try it out with more punch.....the stock setting was super soft....but the laptimes were the best i have run there....first time out with the car. hopefully I can get a little quicker by changing these settings.
Joneser is offline   Reply With Quote
Old 03-30-2005, 11:38 PM   #679
RBLove's Avatar
Awesome. It will definitely have more rip with the changes. It was night and day for me. The biggest thing is the throttle response and current limiter. Turn those off and you will automatically have more rip...
Ray told me you were rolling quite well with the new car. Glad you like it. Junior likes his too. I guess Chicky and I just need to kick some butt and get you guys converted to Losi's............ LOL
Old 03-30-2005, 11:42 PM   #680
well, you and Chicky are in another class all together.....but I think the car shows serious potential. my batteries were less then steller too so between that and changing the speedo, I think I can cut more time. my 3rd run with the car was around 4 seconds off the best runs that Jimmy or Goetz have had. Hopefully the change in freq will not only feel different but equate to some time.
Old 03-31-2005, 12:12 AM   #681
RBLove's Avatar
Ahhhhh. All of you are getting too damn good. You have a great track and great racers EVERY week.
That's awesome you ran so close to Jimmy and Goetz. You will only get better with the car and the speedo changes will help some too.........
Old 03-31-2005, 02:22 AM   #682
Hebiki's Avatar
Trader Rating: 26 (100%+)
RBLove.. you'll have some pretty crazy rip with this setting.. what i do recommend is to watch your car off the start. make sure you are not spinning your wheels..... robert taught me to prevent the wheel spin, always have the first two stages lower drive frequency (higher number on the HHA).
also... do NOT.. i repeat DO NOT use this profile in MOD. i will guarantee you will dump at about 2:30 into your race! (i know because ive done it on accident the one time i ran mod. )
this profile will work really good in 19T too.
dont be shy if you have any more questions.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-31-2005, 02:30 AM   #683
RBLove's Avatar
Killer. Thanks bro.
Wheel spin. What is that? Carpet, foam tires, and Paragon = no wheel spin LOL
Old 04-06-2005, 03:29 PM   #684
Default vfs-1 newbie
Hi all, i am fairly new to rc racin and have just ordered the vfs-1 esc and was wondering with hebiki's suggested stock motor settings what brush life and comm wear would be likely?
cheers for any help
Gray is offline   Reply With Quote
Old 04-06-2005, 03:36 PM   #685
Hebiki's Avatar
Default Re: vfs-1 newbie
cheers for any help
Gray... brush and comm wear is pretty heavy. more than a more conservative setting. say move the entire profile up 5 stages.
id say a cut every 2-3 runs with the settings i posted. brushes can be replaced depending on how long you run your brushes. i replace my brushes every 12-14 runs or so.
Hebiki Design Works
Old 04-09-2005, 02:11 AM   #686
PMR
Default Pls refer me to apage in this thread where.....
Just got my first vfs pro with a handheld and would be using this for mod on a Tamiya 415 with 8-9 turn V2 touring. Problem is I'll be using this set up in a big national race next week and I don't have a damn clue how to set up the esc. I've read the instructions but its kinda complicated. Can you please refer to me a page in this thread where I can find a very well explained basic instruction. I could always mess around with the handheld and get it to work but Im a bit pressured here cuz I'll be running mod, stock and GP all with different cars and given the time table. Thanks a bunch.
PMR is offline   Reply With Quote
Old 04-09-2005, 02:15 AM   #687
Hebiki's Avatar
Default Re: Pls refer me to apage in this thread where.....
here are the instructions on how to set up:
Joneser.. bear with me.. i will try to answer ALL of your questions.
Ok.. the stock settings for the VFS-1 is 36 across the board. search back about 7-8 pages. i posted an excel file that tells you the frequency for each stage number. 36 across is WAY TOO SOFT for stock. i never go above 22 for stock. in fact. i stay in the teens and single digits.
below are instructions on how to program your esc with the handheld adapter. step by step
1. unsolder the motor & unplug the esc from the receiver
2. plug into the hand held adapter.
3. turn on the handheld adapter.
4. hold down the small button the esc switch. then slide the white switch to the on position. the RED LED light will turn on, then off, when it turns on again, you are ready to program.
5. on your HHA (handheld adapter), use the up and down buttons and go to the screen that says RX TX (RX = receive, TX = Transmit)
6. the left button corresponds to RX, and right button on TX.
7. HOLD DOWN the left button until it says "OK" on the HHA.
8. you have received the profile thats on your adapter.
9. program the profile as you wish.
10. scroll back to the RX TX screen. hold down the button for TX (right button)
11. the red led light will flash rapidly. CONGRATS. you just programmed your ESC.
12. turn off the esc. turn off the HHA. replug everything in.
Current Limit of 12 means its 120V. the zero got dropped.
to save your settings that you just programmed:
1. scroll to a memory slot (1-3)
2. program the throttle profile.
3. scroll to the screen that says LD SV
4. hold down the SV button. when it says ok. it has been saved.
5. later, to retrieve the profile. scroll to the slot you saved it in, go to the LD SV screen. hold down the LD button and it'll say "OK"
6. scroll and you will your profile.
hope that helps.
by the way.. visit the Ko site.. has a few mod profiles.
Hebiki Design Works
Old 04-09-2005, 08:38 AM   #688
kylehirano's Avatar
Trader Rating: 14 (100%+)
Hi, Im interested in buying one of these speed controls, Ive always used LRP Quantum 2s. The LRP is easy to set-up, and program. Can someone tell me about the Ko-Propo? Are they just as easy to program. I just bought a EX-10 Helios, and a KO 2363 digital servo and want to keep all my electronics KO.
kylehirano is offline   Reply With Quote
Old 04-09-2005, 09:19 AM   #689
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I only JUST got my VFS-1 on Thursday and first impressions make you think that it is a very complex little unit and hard to use. But when you actually try to do something with it...... its really very easy. Quite simple to understand and if you just read the sheet of paper (commonly known as instructions ) then you should find it a breeze. I've been playing around with the ICS and you really can feel it on the track, its amazing. I think that KO really are the GURUs of speed controllers and without a doubt, I'll be buying KO from now on if they keep this up!!!
PS - VERY happy customer if you can't tell!!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-09-2005, 09:36 AM   #690
kylehirano's Avatar
Do you know if the new Yokomo based Ko-Propo speed controls are programable?
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
