Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 03-13-2005, 05:50 PM
  #631
JimmyMac's Avatar
Uh... Okay!! I'll do it!
JimmyMac is offline
Old 03-13-2005, 06:38 PM
  #632
I understand what the programmer is used for, but does it store settings as well? In other words, if I find a setting I like for stock, can I save it so I can go back to that setting after going to a 19 turn setting?
Joneser is offline
Old 03-14-2005, 06:27 AM
  #633
My 2 VFS-1's arrived today, got a Value and normal one sent over, not like i need 2 doofers is it
Looking forward to seeing it run, just waiting for the FK05 to come out next monday, and we'll see how they both go
I bought mine after fancying the VFS2000 model, but having never seen anyone else run one, decided to play it safe, but seeing as Berger/Karl has just bought one, ive decided to play copycat cos he's started flying with that installed.
Joneser:
I think it holds 3 setups on the card, i could be wrong, and Karl doesnt know either, so on Friday well see if i put a setup onto my card and put it into his reader, my guess is its the card holding it, like a Flash card in there, rather than just a convertor for servo or the esc.
PaulC2K is offline
Old 03-14-2005, 06:53 AM
  #634
They do hold 3 settings. Iv had mine just before xmas and you can turn the wick up when you need it for the final.
Dan Hughes is offline
Old 03-15-2005, 03:27 AM
  #635
Default HELP
i was practising tonight and suddenly the car decided to flip over for no reason and keep rolling until it hit the curb...
a close inspection tells me that the switch for my vfs-1 was broken actually i should say the plastic case for the swtich was broken as the switch itself still functions fine and i can still program it using my hand programmer.
Now can anyone tell me if i can buy a replacement swtich from anywhere? or does someone got a spare switch (or just the case) that can sell to me? i went to KO's website but it seems they don't sell the switch/switch case separately and i don't want to send my ESC back to japan just to replace the switch case..
can anyone help me?
yellow15 is offline
Old 03-15-2005, 06:48 AM
  #636
hey guys,
just wondering can anyone tell me why i should buy this over a gtx, i have a couple of gtx's and perfectly happy, but of ofcourse always looking for something better.
odawg315 is offline
Old 03-15-2005, 09:52 AM
  #637
pimpedaccord's Avatar
Trader Rating: 25 (100%+)
Just stick with what you got if your happy with it. The cost of a new speedo isn't going to help you as much as a bunch of tires or batts since you've already got good speedos.
pimpedaccord is offline
Old 03-23-2005, 09:57 AM
  #638
Could someone help me...
When I introduce a new profile in the Multi stting adapter in Mem1 (for example), I save it, I turn it off--and on again, everything is still in mem 1
But if I turn it off for about 1 week, all the datas are lost and back to set=36??? Does someone has encountered the same problem?
thanks for advice
benoitrdv is offline
Old 03-23-2005, 11:10 AM
  #639
Marcus's Avatar
wat kind of cable do you guys use to transfer the setting from the laptop to the esc. best is that can attach a picture, so i can see how the end of both sides of USB cable look like. thanks in advance
Marcus is offline
Old 03-23-2005, 11:29 AM
  #640
thanks for advice
After saving the data and turning off the hand held you MUST load the data from the memory location. Otherwise, it will appear all at 36.
-Robert
KO PROPO Staff is offline
Old 03-23-2005, 11:37 AM
  #641
Hebiki's Avatar
Trader Rating: 26 (100%+)
Marcus, you'll need the PC Interface from ko propo (http://www.shopatron.com/product/pro...052.1057.0.0.0)
from there.. you can use it if your laptop/PC has a serial connection or you can buy a USB hub so you can use it to plug into the USB port on your computer. (Belkin makes USB/serial hubs) you will also need the software (free download from ko propo - http://www.kopropo.com/ICS.htm)
from there you can create different profiles from your laptop and transfer them to your esc.
Hebiki is offline
Old 03-23-2005, 05:36 PM
  #642
=MisFitz= NuKe's Avatar
Ya...too bad they dont make the software for a Mac....
=MisFitz= NuKe is offline
Old 03-23-2005, 05:44 PM
  #643
Who uses those anyways?
Old 03-23-2005, 06:32 PM
  #644
Hebiki's Avatar
hey!
actually.. macs are awesome for graphics work. i used to have one.. cost me an arm, two legs and a kidney to buy it though.
now.. if the handheld programmer for the VFS could be like the IPOD..and play MP3s.. NOW THAT WOULD BE COOL!
Hebiki is offline
Old 03-27-2005, 04:51 AM
  #645
PizzaDude's Avatar
I think this has allready been asked before, but I wasn't able to trace is asap.
Is it possible to set drag brake?
PizzaDude is offline
