Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 03-07-2005, 10:41 PM
  #616
I tried it but it still has that delayed response. Hmm....this is driving me crazy.
Proteus is offline
Old 03-07-2005, 11:03 PM
  #617
Hebiki's Avatar
Trader Rating: 26 (100%+)
throttle response set to "off" on your VFS?
Hebiki is offline
Old 03-08-2005, 05:00 AM
  #618
HarshGuy's Avatar
Originally posted by Hebiki
JC... i havent tried using my laptop. since i race generally outdoors..and we use small generators.
These days laptops can run off of rechargeable batteries
...I'm using an omnibook 800CT I got off of ebay for like $100 or so:
HarshGuy is offline
Old 03-08-2005, 06:52 PM
  #619
Hebiki's Avatar
ooo.. those things might have a serial connection built-in in the back huh? i should look into that.
i just have my sony VAIO.. but the batts are dying on it. thanks for the tip!
Hebiki is offline
Old 03-08-2005, 07:30 PM
  #620
Entropy's Avatar
I am still quietly waiting for the PocketPC versions of all ICS software to be released.
Entropy is offline
Old 03-08-2005, 07:44 PM
  #621
HarshGuy's Avatar
Yep sure does (have a serial port in the back) and a "popout mouse" ...that's that little "blob" you see on the pic with the opened one, and small to boot, not very powerfull ...but that is all I use it for
HarshGuy is offline
Old 03-08-2005, 08:56 PM
  #622
hey guys....in the pictures I see of Hara running his twister 2, I do not see the capacitor. I may be missing it but I was really hoping it was not a must do. I would like to get one of these (vfs-1 or twister 2) in place of the GTX but I just hate running the caps.
Joneser is offline
Old 03-09-2005, 09:16 AM
  #623
He does but he places it next to the speedo instead of on top. It will void the warranty if you do not use it though.
Dan Hughes is offline
Old 03-12-2005, 07:19 AM
  #624
pimpedaccord's Avatar
Trader Rating: 25 (100%+)
Anybody know what the factory freq setting are? Couldn't find it on KO's site...
pimpedaccord is offline
Old 03-12-2005, 09:38 AM
  #625
berger's Avatar
Its 36 for each step i think, at least thats what the handset resets the speedo to if you tell it to.
berger is offline
Old 03-12-2005, 02:31 PM
  #626
Guo Chean's Avatar
hey does anyone know hara setting for the esc in reedy asia, jmrca, dhi and titc race? thanks
Guo Chean is offline
Old 03-12-2005, 05:45 PM
  #627
OK guys so is this speedo any better than the GTX or QC2....or is it just your preference. I am very interested in getting one but have a couple concerns....1. support at races....at the indoor champs if I have a problem or question, I can go talk to Charlie....2. how easy it to learn....I will be the only guy at the track with one I cant afford a long learning curve.
Eric
Joneser is offline
Old 03-12-2005, 06:57 PM
  #628
Hebiki's Avatar
Eric
Eric
you really cant go wrong with any of the top of the line ESC's. but with the VFS-1 along with a handheld programmer, you'll be able to customize every step of the throttle profile for the ESC. you can adjust it for more punch for (stock) or more efficiency for mod.. or a little bit of both for 19T.
its very easy to learn and you'll have the process down in no time. In terms of support, the Ko site always has multiple profiles on there for different conditions (asphalt, MOD, stock..etc). Any other questions you can always post here.
Hebiki is offline
Old 03-12-2005, 09:13 PM
  #629
JimmyMac's Avatar
My VFS-1 Pro was set with a stock freg of 3.98kHz across the whole throttle range. Right now I'm using an altered 19t technical touring setup. The ESC is very nice. But somestimes a pain if you need to change the setup and you don't have your programmer or laptop with you. Best to get it as the value set.
JimmyMac is offline
Old 03-13-2005, 02:55 AM
  #630
Hebiki's Avatar
Kilruf.. ever try running a stock profile in 19T?
Hebiki is offline
