Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 02-25-2005, 04:21 PM
  #601
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by berger
Chris help, i think my VFS-1 is dead only had 4 runs on it too. I wasnt running a too powerful profile, started about 6 and didnt go any lower than that in 27T. The diode etc was on. My car just slowed and stopped within 10m or so. Took it all off had a good look at everything, tried again in the final thinking it had just knocked off the overheat protection or something. The motor takes a second to accelerate if you hammer the throttle, even without any load on. Tested it with two motors.
Anyway im a bit pissed now, but im going to tear it all down and see if it wants to play silly beggars with me now im at home or not.
Whats KO propo UKs stance on returns in this country as its not sold here yet....
try two things...
1. smell it. if it smells like it toast.. then it is.
2. check your profile.. you said the motor "takes a second to accelerate"... you might have the throttle response set to a number like 9 (1 is the most responsive.. well actually its 0/Off. ) or something. this will cause the motor to accelerate very slowly. i had mine set at 8 once (dont know how that happened) and the car was stuttering. it was very weird. you dont really need throttle response for stock. thats more for Mod where you "feather" the throttle. stock is just ON/OFF
im really hoping its #2. im sorry i dont know the policy for repairs in the UK. let me know how it goes.
Hebiki is offline
Old 02-25-2005, 04:25 PM
  #602
berger's Avatar
Well my whole car smells of TQ after i knocked the can over on the rear of the chassis Gimmie 20 mins or so and ill have it all in bits and see whats up.
berger is offline
Old 02-25-2005, 04:30 PM
  #603
Hebiki's Avatar
you can hit me up on AIM.. or MSN. i'll PM you my info.
btw.. check your diode.. might be dead also.
Hebiki is offline
Old 02-25-2005, 07:12 PM
  #604
gee-dub's Avatar
Default BEC
used the search function, didn't find anything offhand.
anyone elaborate on the BEC voltage for the vfs-1. the US KO site says the following:
"BEC voltage setting (2.5v-4.0v)"
the pro model says this:
"The Pro version comes with the BEC factory default setting at 2.5v"
it seems like just about everything else is 6v. example: novak's bec = [email protected], 5c receiver pack = 6v, 4 alkalines = 6v. trying to understand if this is a misprint or if i'm missing something.
thx in advance.
gee-dub is offline
Old 02-26-2005, 07:31 AM
  #605
Post Multi Setting Adapter Manual
Hello,
I'm looking for English manual for the multi setting adapter and VFS-1 card. I found on page 19 that corallyman has sent a copy to kentech. Could you send a copy to me or post a link here?
Thanks in advance.
Team321 is offline
Old 02-26-2005, 10:51 AM
  #606
kentech's Avatar
Default Re: Multi Setting Adapter Manual
Originally posted by Team321
Hello,
Thanks in advance.
Sent you a pm regarding the manual.
kentech is offline
Old 02-26-2005, 01:27 PM
  #607
berger's Avatar
Seems the first few steps of my profile were too low. Ive spent a while testing things after finding that it did still work this morning and that was the conclusion i came to.
berger is offline
Old 02-26-2005, 07:35 PM
  #608
Hebiki's Avatar
Hello,
Thanks in advance.
how many people need it? i think i have a pdf somewhere (scanned it awhile back for the TAOB Racing site)
Hebiki is offline
Old 02-27-2005, 01:41 AM
  #609
kentech's Avatar
Default KO Multi Setting Adapter Manual
Here it is for everyone that needs it....
File Type: pdf
kentech is offline
Old 03-07-2005, 11:06 AM
  #610
Default Serial to USB Adapter
What brands of Serial to USB Adapters is everyone using? The one I have doesnt work well with the VFS Manager. Just looking for brands confirmed to work.
JC
tiggersz is offline
Old 03-07-2005, 12:44 PM
  #611
Hebiki's Avatar
Default Re: Serial to USB Adapter
JC
belkin makes a good serial/usb adapter.
here's a link:
http://catalog.belkin.com/IWCatProdu...duct_Id=130885
im sure there are cheaper ones. but this was what i found with just a quick search.
Hebiki is offline
Old 03-07-2005, 03:00 PM
  #612
Hebiki: I have a different brand of Serial to USB Converter and Im having issues with it sending to the VFS. It works fine receiving from the VFS. I was looking for something smaller but Robert at KO also recommended the Belkin since he thinks that my serial to usb converter might be the issue.,
JC
tiggersz is offline
Old 03-07-2005, 03:24 PM
  #613
Chris: I have my profile set to one of the stock profiles from the website. I know I programmed the throttle/bk/neutral settings right. But I noticed I have a very large neutral dead band. I'm using an M8. I noticed that the motor (stock)will not turn over until about half throttle. I can hear the esc when i first begin to give it throttle, not enough power to turn the motor until half throttle. Is this normal?
Jeff
Proteus is offline
Old 03-07-2005, 07:48 PM
  #614
JimmyMac's Avatar
This is what I use for my Serial to USB adapter for my laptop computer... http://www.tigerdirect.com/applicati...6218&CatId=464
JimmyMac is offline
Old 03-07-2005, 09:43 PM
  #615
Hebiki's Avatar
JC
JC... i havent tried using my laptop. since i race generally outdoors..and we use small generators. i dont want to tax the gen. by attaching another item like a laptop. ive gotten very used to just imagining the throttle curve and using the handheld adapter (even at home). pretty soon though i will pick up a serial/usb adapter...and try it from home. i'll let you know as soon as that happens.
Jeff
Jeff.. i have a feeling your throttle (full, neutral and brake) wasnt set at factory settings when you set the VFS up.
do this... pick a new model memory in your M8. dont change any settings. then reprogram the VFS for that model memory. then crank up the throttle and turn down your brakes. etc. let me know if that works. (it happened to be because on the Helios.. the throttle is set at 100, and the max is 150) i didnt reset it to factory settings..and i got a delayed response.
Hebiki is offline
