Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 01-10-2005, 12:25 AM
  #511
Nice chap from our local post office waked me up with a pleasant surprise, my VFS-1, double shottky and pc-link were in the package that I received.
I have been reading this thread a lot, but still I wanted to ask what kind of setup you would recommend for handwound 17x2 motors? I was thinking about testing that modified setup from KO's site to begin with. Any comments and ideas are welcome.
copter is offline
Old 01-10-2005, 12:56 AM
  #512
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Re: Re: Re: VFS-1 Stock profile
Originally posted by Dennis Rabanes
chris,
I too ran stock 23T in 5 minute main race. Runtime has never been the case to me until recently as I have experienced fading towards the end of the race. I thought it was my battery at first but I asked a friend to try some of my batts and they were strong from start to the last seconds of the race. So i guess I need to modify the settings on my VFS-1 huh? but it's strange bec it happened recently this two last races ( exactly same settings 3-5 races ago) and I know its not my motor nor my gearing. How do you know if the Caps on the ESC is busted?
Now the real problem- where do you usually set drag brakes? on the ESC or on the radio? I have few motors that are really fast but have more than enough amounts of drag brakes in them and it's costing me few seconds on my lap time. The rear on my car is wiggling everytime i'm off throtlle entering a corner and I have to tap the throttle a little to remedy this but it is slowing me down bec I have to let go off the throotle earlier than I normally do (btw, I'm running one way on the front ) I am certain that the drag brakes on the motor is causing this bec when I change motors the "off throttle wiggling syndrome" is gone hence, leads to my million $$$ question- What's the N.BRAKE and BRAKE FREQ on the vfs-1 are for? maybe that will compensate for the the drag brake on my motor.
Thanks.
Dennis
dennis - for drag brakes. i have yet to mess with the esc setting portion of this. i usually drop my radio settings (Helios) quite a bit. i only race stock and 19T (also with a oneway) and those motors produce enough drag brake for my use. you can use the the settings on your ESC... but use a dbl diode because braking is actually causing a short across the esc. the dbl diode will ensure u dont fry your esc.
start with setting it on your radio first.. then the esc.
Hebiki is offline
Old 01-10-2005, 01:00 AM
  #513
Hebiki's Avatar
Originally posted by ashto
Hi,
I had a bad day today as Ive been running the ko 2000j speedie for a while now and its been great but today at my local club day i went to have my second qualifier in modified touring and as i took off down the straight my car ran out of control and hit a board at full speed.Much damage was caused and the speedie fried. I have been running the large capasitor and had the ko factory high speed open track setting, I also was running the diode on it as well. The speedie has never given me any problems as i have had it in my 1/12 scale and it was working great. I was woundering if i could get any help with an address or some info on why it would have done this. I also checked weather anyone was using the same frequncy as me but not one person was. I also checked all of my other gear and was it fine. After all this i tried to conenct the speedie back up and as soon as i connected it to the battery the motor went at full speed. This is befor i even turned the speedie on. Any help would be much appreciated.
Thanks.
ashto.. and rick.. ive had this happen to me, but it was from a bad crash/hit. i was talking to Robert from Ko and Steve from speedtech and they said what usually happens is this.
you hit something and the force of the impact causes the different boards in the esc (think of them like motherboards on a computer) to move and touch. once they touch. YOUR TOAST. they will short each other out and cause the esc to get fried. the next time you plug it in, it'll do exactly what you said. it'll just keep the motor on full throttle. ive had this happen to my twice. once with a bad t-bone hit. the other was when someone plugged in the esc wrong. (pos. esc wire into the neg plug on the battery.)
so with that in mind, i understand that the esc will not be covered under manu. warranty because its not a defect. the esc was damaged while in use, granted it was proper use, but someone hitting you is a risk we all take.
oh one more thing.. i guess its kinda of unavoidable with the boards touching and shorting in a hard crash. but companies are always trying to make their esc's smaller and faster. the trade off is, in a hard crash, there is less room. and these types of things are more likely to happen.
Hebiki is offline
Old 01-10-2005, 01:03 AM
  #514
Hebiki's Avatar
copter... im crazy enough to run my stock profiles in 19T. what i do is, i overgear the motor and make up for the lack of punch by setting my esc to make up for it. iget the best of both worlds that way. lots of top end and enough rip in the infield. dont try it unless you got good batteries with good runtime. (410+)
Hebiki is offline
Old 01-10-2005, 02:36 AM
  #515
Hi hebiki,
I had not hit anything hard before this happened. as i had it in my 1/12 scale and it was perfect until i put in my tourer. All i did was take off down the straight and it didnt stop. So that to me sounds like a fault in the speedie.
ashto is offline
Old 01-10-2005, 07:44 AM
  #516
I had exactly the same problem as the one you describe. I was using my speedo on an outdoor track, and didn't hit anything. I then bolted in a 9 turn, with all necessary equipment installed. I did 1 aquaintaince lap, and coming onto the straight accelerated hard. I was quite amazed by the speed of my car, but unfortunately it continued to run at full speed. My new 415 was slammed into the barrier and my front suspension broke off. Imho the VFS2000 was not a good speedo. I am using a VFS1 now and it seems to be much more reliable. The most reliable speedo's I've ever used are MRT's however. Never broken a single one.
DavidJoos is offline
Old 01-10-2005, 11:00 AM
  #517
David mine did evactly the same thing! I came around the hairpin at Halifax, started to accelerate around the sweeping bend onto the straight and it pinned on full throttle and would not come off throttle. Before this at the reedy race in the UK also at Halifax my car was fine after coming off the first final, then as it was put down for the 2nd final again the speedo pinned on full throttle and exploded. The first one i had blow up was in my new 414 worlds while racing indoors, again i placed the car on the track accelerated and again it blew up once again holding full throttle till it rammed a barrier. The 4th one will not setup and has a throttle like a switch (the throttle was setup fine untill half way through the first run it adjusted itself and will not reset) so thats sat on the side along with the 3rd dead one, both which had been repaired before going wrong again. Rick
Rick Draper is offline
Old 01-11-2005, 01:32 AM
  #518
Hebiki,
I guess that might work ok for you, but I'm pretty sure that my armature would be done after couple packs with that kind of setup.
I downloaded all 1:10 touring and 1:12 carpet setups into my laptop and browsed those a bit. Setups between 27T, 19T and modified seem to have quite linear difference. 27T has the curve at quite top, modified below middle and 19T in between of those two.
If I would modify that 19T setup and adjust it from the main slider a bit downwards, then it should fit for 17x2 in theory? Or should I adjust every setting separately by counting theoretical value for each by using 19T, 27T and modified setups?
copter is offline
Old 01-11-2005, 02:34 AM
  #519
kentech's Avatar
Default VFS-1
Can you change the settings of the VFS-1 with the PC Interface or do you need the Multi Setting Adapter to do that? Which one would you recommend getting if I only get one of them?
Thanks.
kentech is offline
Old 01-11-2005, 02:54 AM
  #520
You can change settings with PC interface cable only, so you don't need Multi Setting Adapter if you only want to use only PC for changing setups. I didn't bought that adapter since I don't like the idea of browsing menus using small LCD screen.
Only thing that bothers me is the lenght of that PC interface cable (~ 40cm / 16"). It's so short that I need to have my car right next to my laptop or behind it. Double lenght would have made this cable a lot more easier to use, but I guess I just need to get some extension cable or just solder more wire to it.
copter is offline
Old 01-11-2005, 03:12 AM
  #521
Hebiki's Avatar
Hebiki,
slide the whole thing down and have your lowest frequency at around the mid 20s.... and adjust from there. its recommended that you dont go below a certain number (it was 17 for the VFS-2000.. check the drive frequency comparsion sheet i posted several pages back.) for runtime issues / comm wear.. like you mentioned above.
17x2 is a very mild mod but still. dont wanna risk premature wear on your comm or dumping.
Hebiki is offline
Old 01-11-2005, 05:05 AM
  #522
antoniop's Avatar
The setting adapter is incredibly versatile for making changes at the track.
Much better than carrying the laptop around. It's less graphic but you can still save 3 memories on the device and change them very easy.
I just take several blank setting sheets with me in case I need a more "graphical" view of things.
It's an excellent ESC, and the added benefit of making our own profile to suit the motor is unbeatable.
antoniop is offline
Old 01-11-2005, 05:27 AM
  #523
Is it possible to transfer setups between VFS-1 Manager (PC) and Multi Setting Adapter?
I guess it's possible to use VFS-1 Manager and PC-link to transfer setup from PC to VFS-1 and then transfer it from VFS-1 to Multi Setting Adapter, but is there more straight solution for this kind of usage?
copter is offline
Old 01-12-2005, 07:49 PM
  #524
berger's Avatar
Ordered some more KO gear to go in my cuda, anouther 2343 servo (run one in my xray too) and the speedo with setting adaptor for running stock. Cant wait till it arrives.
berger is offline
Old 01-13-2005, 12:21 AM
  #525
Hebiki's Avatar
oooo nice line up.
Hebiki is offline
