Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 12-02-2004, 11:17 AM
  #406
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Just wondering which Ko ESC they are rebadging though..
Randy Caster is offline
Old 12-02-2004, 11:33 AM
  #407
RCGaryK's Avatar
Thanks Picco
RCGaryK is offline
Old 12-02-2004, 11:46 AM
  #408
Default Re: Help
Originally posted by tcmerf
Guys I need help. Although i am not a newbie i sure feel like one now. Just bought the VFS-1 pro and can not get power to the motor. I followed the set up process but when i get to the brake step something goes wrong. I cant get it back to just a solid light, keeps blinking 3 times. am i missing something?
Set you brake to 100% when setting the esc to the Tx.
KO PROPO Staff is offline
Old 12-02-2004, 08:02 PM
  #409
I believe the TRF 2002 was the VFS2000 so that would make that one the VFS-1.
BTW I got my VFS-1 yesterday and this thing is awesome. So small, compact, and light. Can't wait till Saturday to try it out. I already love it more than my Keyence ESC.
NismoSkyline17 is offline
Old 12-02-2004, 08:07 PM
  #410
Team EAM
Trader Rating: 79 (100%+)
Robert are you back at work? Ive got a problem with my speedos and I need to know if youve ran into this before. When runing Mod oval on carpet when I take off under hard accleration the motor acts like the battery is dead for about a half a straight then it takes off and is fine untill I let off the throttle for the next corner... Ive checked the current limiter and its turned off. Ive changed all profiles and reset the speedo...It does it with all 3 speedos. I am running 6 and 7 turns on carpet.
If your at work tomorrow just let me know and I'll call ya.
EA
EAMotorsports is offline
Old 12-02-2004, 08:15 PM
  #411
Hebiki's Avatar
Trader Rating: 26 (100%+)
VFS-1J
Hebiki is offline
Old 12-02-2004, 08:25 PM
  #412
Default Re: Re: Help
Jackpot! Thank you, i was getting very frustrated. One more question. I plan to run this car mostly fro stock, do i still need the schotky diode on the motor or is that only for hotter motors. I hav never used any kind of diode before. Thanks again.
tcmerf is offline
Old 12-02-2004, 08:32 PM
  #413
Hebiki's Avatar
EA
EA.. got the same problem. i know what the problem is and how to fix it make sure your throttle response is TURNED OFF. current limiter you can crank up to 260A. but the throttle response for me was set to 1 i think? or 9? (i forget)...i had the same exact thing happen to me. i turned it off and the car was ballastic again.
Hebiki is offline
Old 12-02-2004, 08:33 PM
  #414
Hebiki's Avatar
Default Re: Re: Re: Help
use the new diode that came with it. if you want more RPM and easier brush wear ... get one of the hyperboosters.
Hebiki is offline
Old 12-02-2004, 09:23 PM
  #415
Entropy's Avatar
Does anyone know or can anyone suggest making a PocketPC version of the ICS software for the VFS1/2000???
It'd be cool bringing a PDA along instead of the whole laptop to the track.
Entropy is offline
Old 12-02-2004, 10:32 PM
  #416
Damn you Chris, I was only going to switch to the KO ESC, but now I'm gonna go KO for everything it looks like... Cant argue with the quality of the stuff, and I always see Robert helping people out at SoCal, win-win.
Old 12-03-2004, 09:57 AM
  #417
EA
EA-
I'm back at the office. The problem that you are having is a common one, the Tokyo office did a demo for me.
When the voltage in your battery pack gets low, stabing the throttle will yeild a slow accelleration. You have two options:
1. roll onto the throttle
2. play with the throttle response to get the throttle to roll for you.
If you have any other questions let me know.
Old 12-03-2004, 09:59 AM
  #418
No PDA software yet. We have talked about it and it may come out later next year, but don't quote me on it. We are now testing a USB version of the PC interface. Once we get all of the bugs worked out, we will release it.
Old 12-03-2004, 10:03 AM
  #419
RCGaryK's Avatar
Yeah, if something makes Chris be fast, it's gotta be fast man
Robert, I am going to send that speedo out today
RCGaryK is offline
Old 12-03-2004, 10:45 AM
  #420
Hebiki's Avatar
another one
Hebiki is offline
