Ko Propo VFS-1 ESC
#331
Originally posted by munrath
Chris,
I wanted to say thanks for the quick response.
Also, as I was looking over the profile you sent and notice they didn't include the following:
N.Brake - assume 0 for stock
Brk. FQ= I was thinking about raising this from the stock setting
Cut. VT = ?
Respons=?
Cur. Lim=?
Thanks again,
Mark
Chris,
Cut. VT = ?
Respons=?
Cur. Lim=?
Thanks again,
Mark
i dont mess with brakes because i dont use them. i only run stock and 19T.. with a one way.. if i use brakes i spin out.. so i just feather the hell out of the throttle.
i will be messing with the response this weekend tho. (settings are 0-9).
#332
Originally posted by ngo8
anyone have a profile for tight carpet touring foam for stock and 19 turn?
#333
It would be super duper great if I can install the ICS software into my pocket PC
#334
Originally posted by Hebiki
i dont do much carpet let alone with foams. but im planning on heading back up to gilroy (our carpet track here in california)..when i do go back.. ill try to get a profile for you.. BUT i would be running stock and 19T on rubber tires. not foam.
#336
Can you guys share a good stock 23T program? Thanks
#338
Originally posted by JasonC
Robert what is the diffrence between
KO PROPO VFS-1 J and the KO PROPO VFS-1 Pro
jason.. im gonna revise the profile i gave you.... you said it was soft in the midrange area right?
#339
Chris,
I took the 27T Technical settings and made some small changes to it for 12th scale stock. I will PM you with the file. Please review and let me know what you think. If you have guys/girls running 12th scale stock ask them to try it and let me know.
ngo8,
Did you have a chance to try one of the profiles on the kopropo website? If so, let us know the Pro's/Con's.
Mark
ngo8,
Mark
#341
Chris,
ngo8,
Mark
Chris,
ngo8,
Mark
saw the profile.. i would try lowering the last 6 stages or so to a lower frequency if you have run time... i gave someone a profile that actually ended in 8 for a VFS-2000 and he said he liked the top end. give it a try.
#342
ok i looked at the profiles at kopropo site i loaded the tight track 27t i think i did it right the instructions are kind of confusing anyway i will have to charge a baterie and see how it works i am just wondering the current limiter is on the 12th step for 27 turn which make sence but i looked at other profiles and the all say 12 which i take it is like cranked would that be good for mod ? i dont get it .
#343
one more thing is on the website it says for example FREQ5=4 is that the same as what the setting adapter says THRT05=FREQ4?
is that the same? thats what was so confusing ?
#344
Scotcky diode
Hey guys, I just bought from a froend a VFs-1 Esc but it did not came with the ultimate scotchky diode.
What other options do I have? I am running 23T can I use the Novak scotchky diode?
#345
you can order one from ko
