Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 08-16-2004, 05:55 PM
  #16
FW-05RR's Avatar
thx Robert and Dave
FW-05RR is offline
Old 08-16-2004, 10:00 PM
  #17
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by FW05R
wow thats nice are there any major differences between VFS1 Pro and the VFS 2000 thats currently out
thx
FW05R - the new VFS now has 64 frequency stages instead of 32 (compared to the old one). so you can really really fine tune the ESC. if you run a lot of mod, they have more frequencies that help runtime. robert told me they did this because in japan, heats and mains are 8mins for both stock and mod.
like dave said.. everything is getting smaller, the new VFS when paired up with the new helios receiver (KR-302F) only takes up the same amount of space as two quarters.
Hebiki is offline
Old 08-16-2004, 10:02 PM
  #18
Hebiki's Avatar
robert... the "J" version of the VFS-1 is the same as the VFS-2000 right? correct me if im wrong, but it saves a little bit of battery for use with steering just in case your batteries just all of sudden dump
Hebiki is offline
Old 08-16-2004, 10:13 PM
  #19
FW-05RR's Avatar
WoW Heibiki thx for the great info sounds like VFS1 is a winner already
FW-05RR is offline
Old 08-16-2004, 11:05 PM
  #20
One thing I've noticed about the KO escs is that it seems like NOONE runs them in off road. Aren't they suitable? Obviously since traction is more of an issue I doubt the super fine tuning is as noticable... But still, if I replace one of my QC2s with a VFS-1 it'd be nice if there were some premade profiles to use for off road...
psbarger is offline
Old 08-17-2004, 02:02 AM
  #21
I think i'll just stick with my vfs 2000 for a while , i will definetly get it eventually (might get it for a xmas present ) when it's out in england (UK)
Chazz is offline
Old 08-17-2004, 02:44 AM
  #22
Default Re: Ko Propo VFS-1 ESC
hey guys... here's the new ESC from Ko Propo. its due out sometime next month. they're taking pre-orders on their website.
go to: http://www.shopatron.com/index/166.0.1052.1057.0.0.0
More info on the ESC:
The new VFS-1 Pro and VFS-1 J will be released soon. Features a smaller footprint, 32 throttle steps with 64 different frequency settings for each throttle step, maximum peak current 3120A (FET specs), Maximum continious current 780A (FET specs) and a weight of 18.8g. Other features that have been added are Neutral brake, frequency of the brake, BEC voltage settting, throttle response, and current limiter. New software and setting card will be available at the same time of its release to program these features.
http://www.kopropo.com/New_ESC.htm
What can be done with this "BEC voltage settting"
Alf
alf.skaar is offline
Old 08-17-2004, 07:46 AM
  #23
Will the Hara Twister be updated to the new specs as well or maybe a Twister2 version be released?
Doug Gaut is offline
Old 08-17-2004, 10:11 AM
  #24
Arrow Pro vs. J
My understanding is that the Pro and J version are the same, because now you can set the BEC voltage. The pre-setting on them is different but can be changed to be the same. The only major difference is the wiring. The J version comes pre-wired with Tamiya style plugs.
KO PROPO Staff is offline
Old 08-17-2004, 10:12 AM
  #25
Default Twister
The Twister will be updated to the new VFS-1. Expect color changes from the VFS-1.
Old 08-17-2004, 10:24 AM
  #26
John_S's Avatar
im with Mr.nuke up there i hope they dont blow up as much as my vfs2000 , because that has blow a few times for no apparent reason in dry conditions. It also didnt even have any of the normal affects of blowing like smoke or heat, it jsut worked one race and not the other
John_S is offline
Old 08-17-2004, 10:31 AM
  #27
Default Re: Re: Ko Propo VFS-1 ESC
Alf
The BEC can be set from 2.5V to 4.0V. I tried to email you but it was returned.
Old 08-17-2004, 10:32 AM
  #28
Mr. Nuke blew his up due to user error and misunderstanding.
Old 08-17-2004, 10:46 AM
  #29
Default Re: Re: Re: Ko Propo VFS-1 ESC
So then the servo will get min 2.5v or max 4.0v i guess this will be interesting to try for 4 cell 1/12
Can i order from you ?
sorry i have a new one
http://www.mineyoursours.com/images/...ilpost_com.gif
Alf :-)
Old 08-17-2004, 10:55 AM
  #30
Default Re: Re: Re: Re: Ko Propo VFS-1 ESC
Alf :-)
Yes the BEC option will make things a little more interesting for 4-cell racing. Email me at support
