Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 07-27-2008, 06:25 AM
  #2461
It appears the only way to adjust the parameters in the Comp 2 is with the multi setting adapter?
Bike racer is offline
Old 12-20-2008, 06:45 AM
  #2462
Default Help on settings for 19T
Hi we are swapping from 27T to 19T and hoping someone can give me a suitable setup. On 27T we have been using a profile modifed from one that from Hebiki published. We use the same shape as Hebiki but start at 20, move down to 11 which is held for while then move up to 30, which has been great for our asphalt track, quite tight with good grip.
We will be using a Check Point 19Tmotor (with sort of dollar bill style label) which I understand is a pretty torquey motor.
Cheers Pete
yellowshark is offline
Old 01-22-2009, 04:19 PM
  #2463
SALINET's Avatar
Default USB Cable for VFS BMC
Hi guys,
Happy New Year to all.
Well, i'm looking for som instructions on how to made my own USB adapter to program the VFS Brushless ESC.
Anyone knows where can I find this information?
Thx
SALINET is offline
Old 01-23-2009, 01:42 AM
  #2464
Originally Posted by SALINET View Post
Hi guys,
Thx
Hi,
If you didn't already know, the USB adapter that I used for my Brushed VFS-1works perfectly for my BMC. Just download the BMC software on KO's website, and your ready to tune your BMC!!
Hope this helps.
Chami
CRiXman is offline
Old 01-23-2009, 05:53 AM
  #2465
Hi all,
I just picked up a VFS-1 comp 2 from Stormer and was wondering about the hand held programmer. I've seen a few used ones floating around but I'm not sure if there is a specific one that needs to be used...? Is there only one programmer that works with all of the VFS series ESC's?
I'm going to be using the ESC in 12th scale, probably 19 turn. Is it absolutely necessary to pick up a programmer to run 12th or is the standard program going to be fine? I'll be running Checkpoint's and Dynasty's primarily.
Thanks!
adam lancia is offline
Old 01-24-2009, 09:25 AM
  #2466
HCS
Originally Posted by adam lancia View Post
Hi all,
Thanks!
There is only on programmer. You just have to make sure you have the VFS-1 setting card that fits into the top. Different setting cards are required for different devices(servo, VFS-2000, VFS-1, etc...)
I dont know if the programmer is absolutely necessary, but its very nice to have. The ability to program drive frequency at different points in the throttle allows you to customize the power band deliver exactly what you need.
I have a spreadsheet that I have been working on that I find useful for keeping track of various setups (2 cars with VFS-1 C2s but dont have the KO Propo USB interface). I can email you a copy if you like.
HCS is offline
Old 03-10-2009, 08:53 AM
  #2467
Arahawak's Avatar
Trader Rating: 32 (100%+)
Hi guys,
I am planning to get the Volac MS C3 ESC, is the onboard settings overkill for a Sport Tuned Motor or do i have to programmed it?
I am running the F1 class..
Newbie to EP
Arahawak is offline
Old 03-10-2009, 11:48 AM
  #2468
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Arahawak View Post
Hi guys,
Newbie to EP
If I'm correct, a sport tuned motor might be the non rebuildable Tamiya motor with brushes.. or a black can mabuchi? either case, you'd want to put a more aggressive profile on there to utilize the VFS to its full potential. There is a profile for mabuchi type motors on the Ko site. check it out.
www.kopropo.com
Hebiki is offline
Old 05-11-2009, 07:51 AM
  #2469
tenpins77's Avatar
does anyone know the internal timing in the speedo?
tim
tenpins77 is offline
Old 05-11-2009, 08:18 AM
  #2470
94eg!'s Avatar
Trader Rating: 17 (100%+)
tim
VFS-1 is for brushed motors, so there is no timing inside. Drive frequency is the only adjustment. The timing is set by the end-bell of the motor can...
94eg! is offline
Old 05-11-2009, 03:03 PM
  #2471
SammyZ's Avatar
Trader Rating: 138 (100%+)
i have a vfs-1 for sale
SammyZ is offline
Old 07-07-2009, 11:23 AM
  #2472
Gig
Gig's Avatar
Default Kopropo VFS-1 Software help
Originally Posted by Gig View Post
Does anyone know if the time adjustment, on the BMC software, can be adjusted in decimal increments. Example: 0, 0.1, 0.2. 0.3..... 1.0, 1.1, 1.2..ETC
So, the standard ICS software V2.0 can be used for any setting accept timing.
The new software called BMC Manger Stock Motor V1.52 has timing adjustment.
Stock brushless can be adjusted for timing between 0-6 (17.5 and 13.5)
Modify brushless adjustment timing can be adjusted 0 to 2 max, any higher timing can damage ESC system. (10.5+)
Is this correct?
What I notice between the software was the frequency range optimization.
Gig is offline
Old 07-07-2009, 05:29 PM
  #2473
Hebiki's Avatar
Is this correct?
do not get this speedo (VFS-1) confused with the BMC esc. there are no timing adjustments in the VFS-1
in the BMC... timing 3-6 is only for 10.5 and lower (13.5, 17.5, etc).
0-2 is for mod motors. (you can also use 0-2 for 10.5 and lower, but it wont be making full use of the BMC's adjustability).
freqs is also different from the VFS-1 due to brushless technology.
Hebiki is offline
Old 07-08-2009, 11:46 AM
  #2474
Gig
Gig's Avatar
Hebiki,
Thanks for the clarification. There kopropo website is confusing. Do you have a good 4wd Touring Car Stock setup for 10.5, 13.5, and 17.5?
What's the difference between the BMC Software manager V1.52 and BMC Stock Manager software? I open them both up. I can't tell the difference. The only difference is display sizing.
Gig is offline
Old 07-08-2009, 12:22 PM
  #2475
Hebiki's Avatar
Hebiki,
the V1.52 allows you to take timing up to "6". the original is only up to "2".
if you need a profile for the BMC for 10.5, 13.5,17.5 check the thread.. there's a couple on there. also the Reedy/Drew Ellis profile from Nats is also good.
Hebiki is offline
