Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 04-11-2008, 06:47 AM
  #2431
Bump. As i could really do with a profile to try this weekend...
Gaz_Stanton is offline
Old 04-11-2008, 07:56 AM
  #2432
Ferrarimk13's Avatar
hey there. the Ko Propo website is great for that kind of info, beause they have the documents on there, for every type of motor, what motor are you runnig?
Ferrarimk13 is offline
Old 04-11-2008, 05:38 PM
  #2433
Yeah, have been through the KO site and done various searches but have only found one profile for 2wd off-road and one for 4wd off-road. As there's no reference to the track surface they were used on it's not a great help.
I want to get testing with this speedo but as there is so much adjustment it would be useful to have a known good start point.
Old 04-11-2008, 07:15 PM
  #2434
Hey Gaz,
Without knowing how many turns your motor is, there is no way for us to recommend anything for you. Describe your motor, your track and your gearing ratio to us, and maybe some of us here can help!
rcnewb2004 is offline
Old 04-11-2008, 10:48 PM
  #2435
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rcnewb2004 View Post
Hey Gaz,
thats what i was waiting for.
Hebiki is offline
Old 04-12-2008, 03:46 AM
  #2436
D'oh!
Going to be running a B4 with Checkpoint 11x2 or 14x2 on a bumpy outdoor astroturf track. The track goes from very low grip when damp/wet to very high when dry. Gearing for the 11x2 will be 21/81 (10.03:1) for a dry track and will be using the 14x2 on 24/81 (8.78:1) if it's damp.
Old 04-22-2008, 05:46 PM
  #2437
Alright guys, just borrowed a multi settings adapter from a friend and am trying to figure it out. I haven't plugged it into the speedo at all yet, but it seems like I can set it to the profile I want and save it.
However, when I am trying to set it, it looks different, instead of saying FREQ XX it says like 3.98kHz. It goes from .93 to 12.00. Most profiles I see have numbers much higher than 12.
Any help greatly appreciated.
JoelV is offline
Old 04-22-2008, 06:32 PM
  #2438
JoelV-
In the hand setting adapter, go to the screen that says "FQ. VIEW". You have this set to "ON". Turn it off and you will get frequency setting number rather then "actual" frequency number.
KO PROPO Staff is offline
Old 04-25-2008, 12:04 PM
  #2439
RocketRacer's Avatar
what is/are the main difference/s between a twister 2.1 and a twister 2.2?
RocketRacer is offline
Old 04-25-2008, 03:09 PM
  #2440
and the new 2.3? they all look the same, lucky i got the 2.2 pretty affordable, $150. Any news on a twister brushless?
Old 04-25-2008, 03:38 PM
  #2441
dstyles's Avatar
here you go
it loses something in translation though
http://translate.google.com/translat...hl=en&ie=UTF-8
dstyles is offline
Old 04-25-2008, 03:54 PM
  #2442
haha,
Commutator with a drawer full power to minimize the pain of combat ultra-profile please enjoy.
i still dont understand what differences there are, all the facts are the same 32 profiles, and such.
Old 04-25-2008, 04:16 PM
  #2443
94eg!'s Avatar
Trader Rating: 17 (100%+)
The difference is probably just the Hara's "special" program that comes pre-loaded in the ESC...
If you have the programmer, it doesn't matter...
94eg! is offline
Old 04-25-2008, 04:37 PM
  #2444
Twister 2.1 has a temp cutoff that is kind of low for people's liking. Twister 2.2 has no temp cutoff, although it has been argued that the temp cutoff is just higher in the 2.2 from the 2.1 (if I remember right, about 10 degrees or so).
Try doing a search within this thread. Its been talked about for sure.
Old 04-25-2008, 05:26 PM
  #2445
Scottrik's Avatar
Trader Rating: 261 (100%+)
I don't remember what the temp difference is on the cutoff, but I DO recall Robert Morris (KO USA service person extraordinaire) et al saying that if the newer unit does get to cutoff that it HAS been damaged.
Also, somewhere along the way, I think off the KO USA site I got the instructions to mod the earlier units to higher cutoff spec--you just have to cut a trace on the PC board iir.
Scottrik is offline
