Old 09-07-2007, 12:45 AM   #2296
Tpg racer's Avatar
Hi all, I have a VFS-2000J esc but I have never bother changing the drive frequency....I noticed the punch level is very low since the 1st day i bought it....maybe its coz of my batteries but can I know how much is the setting equipment???
There's setting adaptor, pc interface and bla bla bla....what do I need actually??? Is there any cable I can connect straight to my laptop without buying all those fancy setting adaptor and so on????
Sorry for the silly question....
Tpg racer is offline   Reply With Quote
Old 09-07-2007, 12:58 AM   #2297
Trader Rating: 17 (100%+)
yes you need pc interface adapter or ICS Multi Setting Adapter
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 09-07-2007, 01:31 AM   #2298
mac853's Avatar
Originally Posted by MoonTrap View Post
Hiya
How important is it to use a schottki diode on the vfs-1 comp2 ?,
i race silver can 540, stock, and 19 turn. I never use brakes during racing. And can you use a normal 5A diode?
Thanks Ya`All
I think using 5A with 540 is acceptable because I am using too, then I saw as well as somebody didn't put nothing in his Volac but is too risky so I never recommend to do the same. I don't know how about stock or 19 spec it depends the track size, maybe MM 12A PCB could try if could find, but the most safety is using the genuine one on these 2 kind of races.
You could take a look from here:
http://www.rctech.net/forum/showthre...ight=esc+diode
mac853 is offline   Reply With Quote
Old 09-07-2007, 01:41 AM   #2299
Tpg racer's Avatar
Anyone knows how to make da ICS serial cable themself??? Care to share???
Old 09-07-2007, 07:11 AM   #2300
no idea
Tamiya TB Evo 5
Old 09-07-2007, 12:34 PM   #2301
Hiya,
Interesting how the speed control gets hot just soldering the cables on, i use a 50w soldering iron, and have in on the post just for 2 seconds to solder the wire, must be really a good conductor , or the 12GA wire conducts heat alot more, and makes the FET's hot while soldering.
MoonTrap is offline   Reply With Quote
Old 09-11-2007, 05:31 PM   #2302
Any word on when the c3 will be available? Prototypes are running at the off-road world's I see...
Yankey is offline   Reply With Quote
Old 09-13-2007, 04:53 PM   #2303
Anyone know what kind of cap this is???
http://www.teamspeedmerchant.com/DonnyLia2007Nats.html
Old 09-13-2007, 06:58 PM   #2304
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
Hiya,
When soldering wires, give ample time for the next wire to be soldered.. heat can damage the esc so bad.
Tin everything that needs to be soldered so that you wont need to put your iron on the tabs that long.. hth's
|JayFlores|2 is offline   Reply With Quote
Old 09-16-2007, 06:56 AM   #2305
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Hey guys I need a little help.
I have a VSF-1 Prof. and I need to set it up in my 2wd buggy. I went to the KO Propo site and I can not get the manual page to open for this speedo. Can some one help me set it up to my Helios. I did notice the little black button on the side of the on-off switch.
Also I'll be running stock and mod 2wd buggy. Will I need to change the settings each time I run the two classes or is there one setting that will work good for both?
Many Thanks
Regards,
Eric
RED-LINE M03 is offline   Reply With Quote
Old 09-16-2007, 07:12 PM   #2306
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Many Thanks
Regards,
Eric
http://www.rcdocuments.com/KO_Propo_...%20English.pdf
Old 09-16-2007, 07:23 PM   #2307
Red-Line,
Are you trying to do basic setup, or program a profile?
Basic set-up:
1)turn radio on
2)hold little button down on speedo
3)turn on speedo and release little button right away (light should now be flashing.)
4)move throttle to neutral and push little button (light should flash two short pulses now)
5)move throttle to full and push little button (light should now flash in three short pulses)
6)move throttle to full brake and push little button.
7)turn off speedo and radio, you are done.
If you are programing a profile, you need the handheld device or pc software/cable.
James
Old 09-17-2007, 06:20 AM   #2308
Thanks Bro....
I could never get that link to work.
Originally Posted by Yankey View Post
Red-Line,
Basic set-up:
1)turn radio on
James
Old 09-17-2007, 07:15 AM   #2309
habis's Avatar
Its a speedmind power cap.......
habis is offline   Reply With Quote
Old 09-18-2007, 12:33 AM   #2310
Tpg racer's Avatar
Anyone???
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
