Old 07-04-2007, 02:26 AM   #2251
over gear's Avatar
Trader Rating: 15 (100%+)
Question. If I use this Muchmore Schottky Diode , do I still need to use the stock Shotki diode for the VFS1?
http://teammuchmore.com/product_info...roducts_id=147
over gear is offline   Reply With Quote
Old 07-04-2007, 03:15 AM   #2252
RBLove's Avatar
Trader Rating: 72 (100%+)
No you do not. The MM will replace, but I recommend sticking with the KO.
RBLove is offline   Reply With Quote
Old 07-04-2007, 03:30 AM   #2253
over gear's Avatar
why is that?
Old 07-14-2007, 01:09 AM   #2254
Hey guys just need some help i have changed radios from EX1 to Futuba 3PK 2.4mhz having trouble programing the speedy every time i hold the button down on the switch and turn the speedy on it goes in communication mode, where i want to set neutral, forward, and brake how do i get in to this mode? to set new radio settings.
cheers Ben
SLIDEQ is offline   Reply With Quote
Old 07-14-2007, 01:36 AM   #2255
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
cheers Ben
sounds like your holding the button down too long . as soon as you see the red light ... let go of the button.. ( takes about .5sec after you turn the ESC on)
JasonC is offline   Reply With Quote
Old 07-20-2007, 11:32 PM   #2256
mac853's Avatar
Could somebody which compete in 540 silver can could share me the setting in small circuits for c1, please?
mac853 is offline   Reply With Quote
Old 07-21-2007, 06:12 AM   #2257
go to www.kopropo.com
and start with technical stock settings
oversquared is offline   Reply With Quote
Old 07-21-2007, 09:27 AM   #2258
mac853's Avatar
Thanks, but honestly I saw it already, I want only to comparing with other guys on forum, due these appeared on site maybe not very useful, than I try before but not very competitive among other guys, even with new motor I am always overtook on straight. Maybe there are some kind to change?
Old 07-22-2007, 04:38 AM   #2259
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
does anyone know where can i send my Hara Twister 2.1 speedo for repairing? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-22-2007, 01:13 PM   #2260
Big B's Avatar
http://www.kopropo.com/repair_centers.htm
Big B is offline   Reply With Quote
Old 07-22-2007, 04:10 PM   #2261
Originally Posted by Hebiki View Post
one advantage to the handheld is its easier to carry around. drawback, no visual representation of the throttle profile. laptop is the exact opposite. pain in the rear to haul around. great visual in terms of the throttle profile.
hope that helps.
Hi, about to invest in the VFS-1 etc. Am I right in thinking that I can setup profiles on the PC with the Manager download software then transfer 3 of them to the handheld with PC interface then transfer 1 of the 3 to the ESC. Or have I got it wrong
yellowshark is offline   Reply With Quote
Old 07-22-2007, 08:27 PM   #2262
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-22-2007, 08:30 PM   #2263
Hebiki's Avatar
check your gearing. this plays a major role on how the esc settings can affect the motor performance.
doing certain things (like lower drive frequencies, it'll give you more punch, but will require more motor maintenance) will affect how the motor behaves, but nothing like gearing.
if your running stock, make sure you turn off the current limiter. its not needed for stock. also if you are NOT running spektrum. lower the power save voltage cutoff to the lowest possible setting.
Hebiki Design Works
Old 07-23-2007, 05:01 AM   #2264
bretthitman's Avatar
Default esc prob
hi has anyone had this problem i bought a vfs-2 about 2 months ago for a offroad car on the weekend i could not get any drive to the motor the lights come on the switch the steering works i reset it so i tied putting my gtx in and it works has any got any ides what could be wrong with the vfs-2 thanks brett
bretthitman is offline   Reply With Quote
Old 07-23-2007, 05:27 AM   #2265
mac853's Avatar
thanks for Hebiki: the stock motor i mean is 540 silver can, so is not possible not have maintenance, but anyway i like to put lower frequencies than recommended on ko's site, the another problem is limit of gear ratio, which is under of race regs., we are not allowed to put lower gear ratio than reg. meant, about current limiter still in doubt, maybe i will change to 2.4g, only thing i could do maybe put lower voltage cutoff .
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
