Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 12-26-2006, 05:05 PM
  #2116
Hugh Jazz's Avatar
Originally Posted by Scrad
Will it even go into the setup mode or not? If you can get it into the setup mode, but can't get the speedo to recognize neutral like mine do, just use some forward sub trim on the radio.
i can't get it into the setup mode, but i did use the trim function on the radio and it seems to work fine.
thanks
Hugh Jazz is offline
Old 12-26-2006, 06:05 PM
  #2117
|JayFlores|'s Avatar
to all the DSM spektrum + vfs1 pro competition users.. what BEC settings are you guys using? thanks
|JayFlores| is offline
Old 12-26-2006, 06:12 PM
  #2118
Guo Chean's Avatar
is better you stay on 2.5v. lower than 2.5v KO only recomemded people who used KO receiver
Guo Chean is offline
Old 12-27-2006, 02:55 AM
  #2119
rampal's Avatar
I have mine @ 4.0v....
rampal is offline
Old 12-27-2006, 08:51 AM
  #2120
4.0V would the setting for spektrum users
KO PROPO Staff is offline
Old 12-28-2006, 02:12 AM
  #2121
sbs
sbs's Avatar
I have set it to 4.0 Volt also
sbs is offline
Old 12-28-2006, 06:27 AM
  #2122
Alex C's Avatar
Trader Rating: 50 (100%+)
Hugh Jazz,
Congrats on your new Speedo.........I will try to help .....If you using a Ko Propo Helios make sure that both your Forward & Reverse setting are set to 100%, and that your trim is set to neutral.
If you are using any other brand of radio system.....then I belive you may need to set both Forward & Reverse setting to the max, and that your trim is set to neutral.
Now the easy part......where you turn on your switch there is a small button that allows you to set both your profiles and inititial set-up.
Now with your battery connected and your transmitter on......press and hold the small black button located on your switch and turn the ESC on, once the esc has been on for one second let go of the black button.......during this period the small led on your switch should be flashing once.
Next leave your tranmitter in the neutral position and press the black button.......during this period the small led on your switch should be flashing twice, at this time pull back on the throttle and press the black button once again.
At this time.......the small led on your switch should be flashing three times,
during this period you should hold your transmitter to the full brake position and depress the black button once again.
After this step you should turn off your esc......and solder in your motor and test the esc for proper operation.
For further documentation.......please feel free to go to KO PROPO USA and look under Support and Manual Downloads.....you can find the link posted HERE.
If you have any other questions please feel free to pm me.
Best Regards,
Alex
Originally Posted by Hugh Jazz
i just got a twister 2.2 for xmas and i am having problems trying to get it set to the transmitter. I can get it into communication mode and change profiles using the computer.
any help would be appriciated
Alex C is offline
Old 12-28-2006, 07:22 AM
  #2123
ghoppa's Avatar
Trader Rating: 63 (98%+)
"what is BEC??" I to have Spektrum & the Twister 2.1, do I need to change the factory settings?????
ghoppa is offline
Old 12-28-2006, 05:44 PM
  #2124
rocketron's Avatar
Trader Rating: 16 (100%+)
Set the BEC to the 4.0v setting you maybe able to run the next lower but I know this works very good. (Standard default is 3.0v i think )
rocketron is offline
Old 12-28-2006, 06:09 PM
  #2125
Hugh Jazz's Avatar
Hi Alex C,
thank you for the advise. I have followed what you have said but my problem is that the light will not flash once, twice etc. other than that it works fine. Iam also using the KO Helios
Cheers
Daniel
Old 12-28-2006, 06:59 PM
  #2126
Kenneth Tan's Avatar
Hi Alex C,
Cheers
Daniel
Ever tried reversing your throttle channel on your transmitter? I was using the Sanwa RX-431 receiver with the Twister 2.1 and it was acting funny. I reversed the throttle channel and the setup lights work fine now.
Kenneth Tan is offline
Old 12-28-2006, 08:33 PM
  #2127
|JayFlores|'s Avatar
thanks ramapal, KO PROPO staff & sbs. changed it and solved the rx failure when running mod.
Old 12-28-2006, 08:50 PM
  #2128
Quick question:
I've heard the hara twisters come with no warranty, but if something were to happen to it, would I be able to pay to have it fixed?
JoelV is offline
Old 12-29-2006, 08:34 AM
  #2129
ghoppa's Avatar
thanks Ron, but what exactly is "BEC"???? "school me", I am a nitro dude....
ghoppa is offline
Old 12-29-2006, 02:55 PM
  #2130
Scrad's Avatar
I think it means battery eliminator circutry. I.E. no battery pack.
Scrad is offline
