Ko Propo VFS-1 ESC
#196
Originally posted by Aku-Man
I'm thinking about getting VFS-1 valve pack. There's no info about setting adaptor on the website. Is it easy to use? How's it compare program on computer?
it has four buttons and pretty intuitive. once you get the hang of it, you'll be zooming along. the program on the computer is really very visual and useful. you can create programs alot faster and more efficiently but it requires a laptop if you want to bring it to the track. like rc-zombies said.. you can program at home, store it in the handheld..and bring it to the track.
OR like robert does (ill soon be doing this also) just bring your laptop to the track and program from there.
mr rc-zombies.. u get discover any good stock/19T profiles yet? robert wont share his secret set up!
#198
Originally posted by KO PROPO Staff
The setting adapter is our new universal programmer. You will just need to insert the correct card for the application that you will be using. Currently, there is the card for the VFS-1 and the servos.
#199
Originally posted by RC Driver Gary
So here's the 64,000 dollar question...will the VFS-1 setting adapter be compatible with my VFS-2002?
#200
If you are running the same car (12th scale in this case) in both stock and mod (Cleveland as an example), I just wanted to check that you can't switch between the two profiles without using either the setting adapter or laptop?
With the laptop you have to have power to the speedo, is that the same with the setting adapter?
#201
You will need either the setting adapter or the laptop to change the profile and power for the speedo for both.
#203
Hi, KOPROPO staff,I have two hyper boosters, but I don't see many people use it especially in mod. How much it helps, lets say in 19t class, should I use them? Also is it really so easily damaged by static eletricity? Thanks.
#204
#205
#206
Originally posted by Hebiki
robert... im still reading your PM.. (over and over) make sure im reading it correctly!
#207
Registered User
Just order VFS-1 Pro Value Set.
Why you guys have to post all those positive feedbacks, I couldn't hold my wallet.
I should received it on friday. Anybody got good set up for 19Tspec? I want to compare with my Q2 on saturday's race.
#208
Today I got my VFS-1 Pro Value Set
But the manual is in Japanese. Looking at the pics I can sort of understand how to calibrate the radio, but is there anyone that can help me on this one?
A english manual, a short description...
#209
there is a manual online (in semi-English) on the web site
#210
Hum...
canīt find it on the US or the Japanese site...
It's just for the radio calibration part.
