Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 07-08-2006, 07:23 AM
  #1951
Trader Rating: 17 (100%+)
Originally Posted by SpeedTech
Hi Guys,
Special discount this weekend for all KO Propo ESC and ESC Value Set:
KO Propo VFS-1 Pro Competition Version Only $154.99 and our Grand ReOpening special 5% discount for electronics can still be applied
KO Propo VFS-1 Pro Competition Version Value Set (w/hand held programmer) only $199.99 and our Grand ReOpening special 5% discount for electronics can still be applied.
This is a great time to pick up a second speedo for your car. KO Propo ESC are one of the most popular speed controllers used by the top pro-driver, and it is the most adjustable ESC on the market today! Price is good while supplies last!
Thanks!
Steve Wang
Hi steve, Grand ReOpening special 5% discount for electronics is this apply to all electronics?especially the helios. thanks
EngTat
EngTat is offline
Old 07-10-2006, 05:47 PM
  #1952
Trader Rating: 16 (94%+)
is it possible to order a replacement case for the switch? can't find it on the site...
domo is offline
Old 07-11-2006, 07:17 AM
  #1953
Trader Rating: 81 (100%+)
will a higher/lower frequency setting affect top speed? or does it only have an effect on acceleration/punch?
marvi is offline
Old 07-11-2006, 07:52 AM
  #1954
mazmo's Avatar
Default frequency settings
Marvi, general rule is higher frequency settings reduce punch but increase top end speed. So I guess lower frequency at early throttle settings moving progressively to higher frequency at latter throttle positions would achieve "the best of both worlds".
Hope that helps
mazmo is offline
Old 07-11-2006, 11:38 AM
  #1955
hi, will a standed diode work on a hara speedo??
mwoods is offline
Old 07-11-2006, 11:40 AM
  #1956
rc-zombies's Avatar
yes.. I use Novak's new 36amp diode on mine.
rc-zombies is offline
Old 07-11-2006, 02:17 PM
  #1957
SpeedTech's Avatar
EngTat
EngTat,
yes, it did applied to all electronics, unfortunately that special was good only from July 1st-July 4th.
We do still have the KO ESC on sale right now (VFS-1 Pro Competition and the Value set)
Steve Wang
SpeedTech is offline
Old 07-12-2006, 03:59 AM
  #1958
Originally Posted by mazmo
Marvi, general rule is higher frequency settings reduce punch but increase top end speed. So I guess lower frequency at early throttle settings moving progressively to higher frequency at latter throttle positions would achieve "the best of both worlds". Hope that helps
thanks for the info its my 1st time to use the vfs1, stock racing this weekend. ill just stick to what i got from ko's site for setups. ill also try the one heibiki posted
marvi is offline
Old 07-12-2006, 05:27 AM
  #1959
rampal's Avatar
Hi
Just get an VFS-1 pro and it will be the first time that I will solder the wires to the esc.... Do I have to worry about overheating the solder posts? What is the best way to solder them? I was looking for putting both the shottki and the condensator right next to the ESC... capacitor on its side and shottki over it... does anyone has this configuration? What do you solder first? I will use a 60W solder with a flat tip, that works pretty nice to solder battery tabs... however the ESC is so tiny!!! I was used to bigger and cheaper ones... Pretty nice stuff!
Any help will be more than welcome!
Thanks a lot,
rampal is offline
Old 07-12-2006, 06:57 AM
  #1960
Just a quick question concerning an older VFS-2000 ESC.
I'm running this ESC in a 12th scale car, is it possible/okay to do this without the capacitor?
I have seen others remove the large capacitor on other brands of speed controls in their 12th scale cars in order to save space.
If I could do this, I would be able to mount the body lower on the car.
Rugrat is offline
Old 07-13-2006, 08:33 AM
  #1961
EngTat,
Steve Wang
thanks
EngTat
EngTat is offline
Old 07-13-2006, 10:57 AM
  #1962
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rampal
Hi
Thanks a lot,
try to have it on there so long. just enough to melt the solder. any longer, and it might damage the FETs inside the esc.
you can also solder the diode on there... some pros have done this, so you can search around for a photo. i think Hara did it on his car. and then you can place the cap on top.. or to the side of it.
Hebiki is offline
Old 07-20-2006, 03:05 PM
  #1963
cyclone's Avatar
does anybody no where i can find an instruction manual for a twister2 (vfs1) on the interenet? cheers
cyclone is offline
Old 07-20-2006, 05:13 PM
  #1964
XrayFK's Avatar
KO's website is a good bet: http://kopropo.com/manuals.htm
XrayFK is offline
Old 07-21-2006, 04:06 AM
  #1965
Nicadrauspro4's Avatar
bump!
Nicadrauspro4 is offline
