Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 05-12-2006, 11:48 AM
  #1891
Originally Posted by Charles
That's what I thought you had said earlier, Robert. So I am using the pro only. I moved the cap and the super shotke off the top of the esc. Plus I have added a fan. I will see how that goes tomorrow
Charles-
Try the copper heat sink that we offer. It makes a big difference in the esc temperature. A fan with the heat sink would only make things better.
-Robert
KO PROPO Staff is offline
Old 05-12-2006, 12:15 PM
  #1892
Trader Rating: 17 (100%+)
Originally Posted by KO PROPO Staff
That is called lost in the translation. It does still have a cutt-off, but if it is activated most likely something is damaged.
thanks for the info
does using the hyper booster improve the vfs 1?
EngTat is offline
Old 05-12-2006, 02:51 PM
  #1893
Originally Posted by EngTat
thanks for the info
I would not use the hyper booster with any of todays newer batteries and motors. If you are going to run a standard mabuchi then you'll probably be ok. The problem is the current output and draw of todays equipment far exceeds the specs at which the hyper booster was designed for.
Old 05-12-2006, 03:54 PM
  #1894
thanks, how about the vfs2000 with the current motor/batteries?
EngTat is offline
Old 05-12-2006, 04:15 PM
  #1895
No. That is why we have discontinued it. If we were to make and updated one that will not become damaged with the current motor/batteries, it would be way too expensive. The original hyper booster was expensive to begin with!
Old 05-12-2006, 04:40 PM
  #1896
thanks
EngTat is offline
Old 05-21-2006, 12:21 AM
  #1897
rc-zombies's Avatar
Robert...
I think I blew a fet in my Twister 2.1
where do I send the speedo to? to KO or to HB?
lmk thanks
rc-zombies is offline
Old 05-21-2006, 01:04 AM
  #1898
prodrive's Avatar
Default download
i just got vfs-1 without user guide or manual. where can i download the manual?????????
prodrive is offline
Old 05-21-2006, 01:38 AM
  #1899
Hebiki's Avatar
Trader Rating: 26 (100%+)
http://www.kopropo.com/manuals.htm
Hebiki is offline
Old 05-21-2006, 05:06 AM
  #1900
Stusdal's Avatar
got a VFS-1 pro and just got a ICS Multisetting adapter. Where do I find good profiles to try out?
Race mostly SuperStock(19t)
Stusdal is offline
Old 05-21-2006, 05:21 AM
  #1901
Try going to the KO Propo website... they should have a list of settings there for you to try.
rcnewb2004 is offline
Old 05-25-2006, 03:53 PM
  #1902
Qwiglee's Avatar
Where can I get a replacement case for my VFS-1? I have melted the corners while soldering, it still works but it just looks fugly. I didn't find it on the "Shopatron" on the KO website.
Qwiglee is offline
Old 05-26-2006, 04:41 AM
  #1903
Default Repairing of VFS-1 pro
KO staffs,
What is happening to KOpropo Japan? I have sent my VFS-1 pro for repair and i still have not hear from them for 4 month. I have sent e-mail to them but no reply till todate. Quite disappointed with their level of services. I hope someone can help me as I have loss faith in them.
Rgds
SY
thesaint is offline
Old 05-27-2006, 11:05 AM
  #1904
what good are vsf1 27 setups?
Smoking motor.. is offline
Old 05-29-2006, 02:11 PM
  #1905
robk's Avatar
Trader Rating: 22 (100%+)
I had my VFS1 pro thermal shutdown a couple times yesterday. The track was about 120* and this was with a 7 turn. Can anyone recommend where to start on the frequency to avoid getting the ESc too hot? BTW what does Hara do in Thailand? It's really hot over there...
robk is offline
