Ko Propo VFS-1 ESC
#1846
nicadrauspro4
the reason i ask was hooked up cable and tried to set the esc and kept getting communication error, trying to figure it out
to get in communication mode i held set button down and turned on switch held till light went out as per instructions
when released set button light came back on is that normal
just making sure i'm doing it prperly
thanks
thanks
#1847
anyone know what are the amp rate for ko shotki diode, the single and double. thanks
#1848
Single: 15A, 20A
Double: 30A, 40A & 45A
#1849
with the twister 2.1 do i need to run the condenser that came with it, i'll be running stock 4cell oval on carpet
#1850
Originally Posted by Nicadrauspro4
Amp rate for shotki diodes
Single: 15A, 20A
Single: 15A, 20A
#1851
i am little confused here, i thought kn only have the single #45515 and double #45516. why do it have so many rating? thanks
#1852
Originally Posted by Guo Chean
single if i not mistake is 4 regular shokti diode and double is 8 regular shokti diode normally we used 5amp regular shokti diode so it may 20amp shokti diode for single and 40amp for double shokti diode
http://www2.towerhobbies.com/cgi-bin...?&I=LXUE62&P=M
http://www2.towerhobbies.com/cgi-bin...?&I=LX2682&P=7
is this consider single? what the rate for the ko regular? thanks
#1853
is it is 9A then the single would be 9x4=36 and 9x8=72Amps
can anyone verify the ko spec...
#1854
anyone know the rating for the diodes?
#1855
Single 80A
Double 160A
Double 160A
#1856
power switch
KO PROPO Staff.
How do I get a new switch cover? Where can I order one from and is there a part numer?
Thanks,
E
Thanks,
E
#1857
hi, im having a bit of a problem with my Hara Twister 2.0.
foolish me have been running the ESC without no shotky and powercap so the Brake-Fets burned out. well its just one but the brake doesnt work anymore...
is there a shop anywhere in the world that sells Brake-fets and ships international?
I'd be glad if someone could give me a link or something. my LHS cant get this and contacting Ko-propo directly ends up in me having to send in the ESC for repairs wich will cost me about 20 dollar just to get it to ko-propo without even the repairs and the shipping back.
i guess i can solder them in my self so that wouldnt be a problem
Many Thanks
Mark
Many Thanks
Mark
#1858
Many Thanks
Mark
Many Thanks
Mark
If you've damaged the brake FETs, more then likely you have also damaged something else. You may not notice it at first until it stops working. Trust me, I fix them everyday.
-Robert
Last edited by KO PROPO Staff; 10-21-2013 at 12:19 PM. Reason: -asked to remove name from post
#1860
so I should just send it in for repairs??
can we telk by mail or something?
that'd be great
Mark
that'd be great
Mark
