Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 03-28-2006, 10:53 AM
  #1831
B&B Racing's Avatar
Here is what the manual says to do:
  • Hold down the set button while switching the power to the ON position. Hold the button down until the LED light comes on and release.
  • The LED light will repeat a pattern of flashing once. Leave the throttle trigger in the neutral position and press the set button once.
  • The LED light will repeat a pattern of flashing two times. The throttle trigger should be pulled to the full forward position and held while the set button should be pushed once.
  • The LED light repeats a pattern of blinking three times. The throttle trigger is pushed to the full brake position and held while pushing the set button once.
  • When the standard setting is completed, LED will remain on and full operation of the throttle/break is possible. Turn the power off and connect the motor. When the power on/off switch is cut before a standard setting is completed, the setting is not memorized. You will need to perform the setting of the speed controller again.
The only time that I have not been able to complete this standard setting mode is when the CPU fried in our Twister 2.0 ESC. That required a complete replacement as it could not be fixed.
B&B Racing is offline
Old 04-04-2006, 02:57 AM
  #1832
acutts's Avatar
Hi All hoping someone can advise on a problem I have with the vfs-1. The ultimate schotty diode that attaches to the motor keeps getting destroyed on my Xray as it sticks out so I was wondering whether I could solder it direct to the pos and neg on the esc?? This would make changing motors and paying $25 for a replacement much better.
Any help appreciated.
acutts is offline
Old 04-04-2006, 03:10 AM
  #1833
Stein Tumert's Avatar
Yes you can...may be a bit less effective, but works. Many people around here does that...
Stein Tumert is offline
Old 04-04-2006, 04:30 AM
  #1834
Nicadrauspro4's Avatar
Works just the same if you solder it directly to the ESC's positive/negative terminals. Wrap the contact wires with shrink tube to protect it from short circuit.
Nicadrauspro4 is offline
Old 04-11-2006, 12:00 AM
  #1835
acutts's Avatar
I am going to be doing this .... just to confirm though I connect it to the esc's + terminal and the middle (blue) terminal that goes to the motor ... not the terminal that goes to the battery?
acutts is offline
Old 04-11-2006, 12:56 AM
  #1836
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hebiki is offline
Old 04-11-2006, 03:40 AM
  #1837
Connect it to both motor terminals on the ESC, blue and red. Check the diode's polarity well before soldering.
Old 04-11-2006, 03:46 AM
  #1838
acutts's Avatar
Connect it to both battery terminals on the ESC, black and red. Check the diode's polarity well before soldering.
Surely this is wrong .... it is a diode and goes on the terminals that feed the motor????? As generally you have it direct on the motor!
acutts is offline
Old 04-11-2006, 03:54 AM
  #1839
B&B Racing's Avatar
Good catch!! You would put it across the MOTOR terminals on the ESC.
Old 04-11-2006, 04:27 AM
  #1840
Oh yeah...
My mistake. Sorry for that. I'm still in a daze.
Old 04-11-2006, 05:38 AM
  #1841
Stew Noble's Avatar
Try using a externally mounted diode, this one is Novak, but MuchMore now make two too.
Stew Noble is offline
Old 04-11-2006, 09:50 AM
  #1842
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default condenser/shotki
do I need to use the ultimate condenser for stock rubber ? and where can I get a shotki diode thanks
Customworksking is offline
Old 04-15-2006, 05:15 AM
  #1843
rattlr2's Avatar
just recieved twister2.1 can anybody tell me if the pc adapter cable from the original twister will work? tried to email ko, no reply so i'll see if they answer on here
if cable is different which one do i need
thanks
rattlr2 is offline
Old 04-15-2006, 05:52 AM
  #1844
2-Bad's Avatar
Trader Rating: 24 (100%+)
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
2-Bad is offline
Old 04-15-2006, 06:18 AM
  #1845
thanks
The cable will work on both models.
