Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 03-16-2006, 07:09 AM
  #1801
cyclone's Avatar
so can the twister 2/ 2.1 and the rest of them... be set without a pc or the setup machine thing ( excuse the numb langauage here im just working out whats what with the latest esc's...)
also what is required to set one up on the pc's, +what do you actually do?
cyclone is offline
Old 03-16-2006, 07:22 AM
  #1802
Hey cyclone,
I do not think the Hara2.0/2.1 can be set without the pc or the handheld. But the speedo will run well if u are racing mod motors even without any programming.
To set one up, all u need is a pc, a cable to connect the speedo to ur pc, and software u can download from the KO site.
rcnewb2004 is offline
Old 03-16-2006, 10:57 AM
  #1803
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rcnewb2004
Hey cyclone,
dont forget.. the PC Software is free
also.. the handheld programmer can also program the Ko Propo line of ICS servos
Hebiki is offline
Old 03-16-2006, 01:42 PM
  #1804
Nicadrauspro4's Avatar
3 questions to anyone who would want to answer.
1. Aside from the original KO Propo VFS-1 and other models such as Twister 2.0/2.1, Yokomo Masami model, RS-43/43C Rayspeed model, MMS-3 Corally model, and Volac Tamiya model, what other VFS-1 models are there that I have not mentioned?
2. Which among these models has the best factory programming?
3. Which model is the most popular and consumer favorite?
Nicadrauspro4 is offline
Old 03-16-2006, 01:48 PM
  #1805
rc-zombies's Avatar
2. Hara Twister 2.0 / 2..1
3. same as above
rc-zombies is offline
Old 03-16-2006, 01:54 PM
  #1806
berger's Avatar
Alex racing do a range complete with bling heatsink available in a rainbow of colours!
People buy the Hara for the name really, with the programmer, which you should have to make the most of the speedo imo they are all equal.
berger is offline
Old 03-16-2006, 07:05 PM
  #1807
Hebiki's Avatar
3. same as above
zombies.. your biased to purple tho ... Volac (VFS from Tamiya) for the guys that like blue. or if you have an RDX... MMS from Corally. etc.. etc..
you know RC racers...everything has to match.
Hebiki is offline
Old 03-16-2006, 09:17 PM
  #1808
rc-zombies's Avatar
Hara Twister...not just for the name or purple bias... it's also has the best price.... $134 at Tower.
Old 03-17-2006, 12:23 AM
  #1809
HEY GUYS I THINK MY TWISTER 2.1 IS BLOWN WHEN I TURN THE UNIT ON NO LED IS ON AT THE SWITCH AND JUST ROTATES THE MOTOR AT VERY SLOW SPEED . EVEN IF I PULL THE TRIGGER, NEED HELP? IAM FROM AUSTRALIA SO IF BLOWEN WERE DO YOU SEND UNIT TO GET FIXED.
CHEERS BEN
SLIDEQ is offline
Old 03-17-2006, 02:33 AM
  #1810
Technoskid's Avatar
KO Twister 2.1 has the best. Hara setting profile speaks for itself.
Technoskid is offline
Old 03-18-2006, 09:46 PM
  #1811
teabag's Avatar
i installed the 27 turn settings someone posted up here, it started at 5 and ended at 24, the motor sometimes wont turn over early in the throttle, I hear the electronics whining like it wants to turn the motor over but it doesn't. this is even with the pinion off
teabag is offline
Old 03-19-2006, 06:15 AM
  #1812
Hebiki's Avatar
CHEERS BEN
Ben,
The FETs inside your ESC is fried. send it into your ko propo dealer down under for repair.
- Chris
Hebiki is offline
Old 03-19-2006, 06:16 AM
  #1813
Hebiki's Avatar
whats your setting for throttle response? also, reset the esc to the radio (resetting the neutral, full throttle and full brake). let us know if that helps?
Hebiki is offline
Old 03-19-2006, 05:55 PM
  #1814
Lower frequency will always have some deadband on the throttle. High frequency gives better response. Also, starting at 5 is way too low. You should start at 15 and go down to 7 when you are at step 10 and go back up.
trf_racer is offline
Old 03-19-2006, 06:29 PM
  #1815
teabag's Avatar
thanks for the help hebiki and trf, i ran it at a parking lot race and it was great for the first lap of practice then i blew the cap out. is this due to the settings too low?
teabag is offline
