Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 02-06-2006, 04:12 PM
  #1756
woozer71's Avatar
Trader Rating: 23 (96%+)
This might be a stupid question, but do the profiles change when you go from 3300 cells to 3800 cells? I have heard that you have to change but I will ask the experts.
woozer71 is offline
Old 02-06-2006, 07:37 PM
  #1757
The profiles themselves do not change. However you now have greater capacity and good voltage for longer periods of time, u may want to change your profiling to adjust for this...
At least that's the way I see it...
rcnewb2004 is offline
Old 02-12-2006, 07:57 AM
  #1758
Formula1fan's Avatar
I have been using my speed control in a 12th scale on the high speed track settings. I had a friend program it for me. I recently bought a programmer myself and need to program it for technical track. When I did this the car was felt really flat and I dumped while running a conservative rollout and 3800 batteries. I did the setting listed on KO's site, but there are some things that confuse me:
1. I do not have the "CUT. VT" that is listed
2. The set up say "CUR LIM=12" I assume this means 120
3. My programmer does not start at "FREQ0" and ends in FREQ32, should I
move everything up one?
Formula1fan is offline
Old 02-12-2006, 04:02 PM
  #1759
Hebiki's Avatar
Trader Rating: 26 (100%+)
Formula1Fan:
1. cutoff voltage is what the esc will save from your batteries if its nearing to dump... 2.5, 3.0.. etc. once your batteries dump, then you'll only have enough to use the steering to move your car out of the way. this is how i remembered it. i could be wrong.
2. CUR LIM stands for current limiter. 12 does NOT stand for 120. search back about 8-10 pages. you'll see the explaination for the numbers.
3. FREQ0 is considered "stage 1". FREQ32 is the last stage. the numbers underneath are the drive frequencies. program those as you see fit for your track and car conditions (lower number means lower drive freq., more punch, more brush, comm wear, shorter runtime.... high freq, means more efficiency, more top end, rpm, less comm wear, longer runtime
hope that helps.
Hebiki is offline
Old 02-12-2006, 08:06 PM
  #1760
I am using a spektrum and I thought I was suppose to set the cut off at 3.5. If 12 does not mean 120, I am really confused, because on my programer it starts a 300 and I dont think I could get it down to 12.
Old 02-13-2006, 01:24 PM
  #1761
Hebiki's Avatar
yes, for spektrum leave it at 3.5V. here's what 12 means for the current limiter.
Originally Posted by KO PROPO Staff
You are probably opening the file as a text document and the numbers do not correlate to voltage settings, for example 12=120A. The numbers do not work that way. If you insist on opening it with notepad, here is the reference.
0=40A
1=60A
2=80A
3=100A
4=120A
5=140A
6=160A
7=180A
8=200A
9=220A
10=240A
11=260A
12= OFF
If you have a doubt about the setting, use the PC software to open the file. It's FREE.
12 means you are turning off the current limiter.
Hebiki is offline
Old 02-13-2006, 06:05 PM
  #1762
berger's Avatar
Chris have you tried a profile with fairly big jumps between each step, of 3 or more? I ask as i find i need a little more top end, but want to keep the rest of my profile similar to what it is at the moment. If i staged it up greatly in the last few steps, would it be noticable or have an adverse effect on how it drives?
Im using something similar to your recommended stock profile i think, maybe a little lower...
berger is offline
Old 02-13-2006, 09:59 PM
  #1763
Hebiki's Avatar
nope. but i have asked robert that question. his response was that the esc wont be as smooth, maybe have a choppy feeling? ive only done every other.
id say try it out in the last 4 stages of the profile.. if your track doesnt require letting off around 1/4-1/8 off of the throttle. let me know what happens. i can try it out for you... but i donated all my batteries. and i gotta order new ones.
Hebiki is offline
Old 02-14-2006, 11:58 AM
  #1764
Formula1fan- Try opening the setting files with the software. It makes everything easier. You can donwload the software for free.
KO PROPO Staff is offline
Old 02-14-2006, 01:33 PM
  #1765
jrighter's Avatar
How do you import the files within the software? I have downloaded both the files and the software and there doesn't appear to be a way to import it.
jrighter is offline
Old 02-14-2006, 01:39 PM
  #1766
You have to remember where you saved the file, then open it from that location.
Old 02-14-2006, 01:43 PM
  #1767
jrighter's Avatar
I've done that. I saved the settings on my desktop and have the software open. Is there a button within the software to import the text file? I know where the text is saved...
jrighter is offline
Old 02-14-2006, 01:45 PM
  #1768
jrighter's Avatar
Here is the screenshot of the software. The bottons on the bottom do nothing for me at this point...
File Type: doc
jrighter is offline
Old 02-14-2006, 02:12 PM
  #1769
kerry's Avatar
right click on the screen will give you options from there
kerry is offline
Old 02-14-2006, 02:19 PM
  #1770
jrighter's Avatar
It worked! Thanks a million!
jrighter is offline
