Ko Propo VFS-1 ESC
#1577
Hello,
I'm looking for the program that comes with the Hara Twister 2.1 (latest version)
Thanks in advance.
Hugo
Thanks in advance.
Hugo
#1578
Originally Posted by TFR
Here is a more clear picture for you to see.
but, it looks like they are out of stock
#1579
Originally Posted by macvolcom
Here http://www.speedtechrc.com/store/ebp...nid=64&id=1148
normally its red/black/white, in the pics he has shown they are all black coming from the twister!
#1580
At this moment, I don't know where you could buy them. Sorry. They do look nice.
-Robert
-Robert
#1581
Does any one run this speedo in there 1/12 scale if u do how do u like it
#1582
Originally Posted by Mark Payne
Hi Robert
Now you said this to me also. I removed the red wire from the plug and taped it back on itself.
I programme with the handset and I have found that i DO NOT have to reconnect the +ve.... are you sure you have this right?
Cheers
Mark
Cheers
Mark
You are correct. Looks as though you don't need the positive wire installed to program. Sorry.
-Robert
#1584
I am very interested in buying a VFS-1 pro comp. and and only problem I can think of is the fact that I haven't heard how to program and set the controler with the programing tool the value pack comes with. Their are no LED's to read off of like the QC2. How does the Ko Propo esc work.
I plan to use it in my FT B4 with a 12x2 V2.
Thankyou.
Thankyou.
#1585
2 ways to program the esc. a handheld programer or a special computer cable. both are easy to use and you just plug your esc lead into either one and set it up for different track conditions, i have been using mine for a month now and it is great. i am able to adjust reponses to track conditions. these units are easy to program don't worry.
#1586
Thankyou,
Kerry
#1587
Why don't a lot of racers use the Ko Propo VFS-1 pro comp. in their off road cars?
#1588
There is a diode comes with the ESC, and by mistake i solderedthe negative to battery's negative side rather than the motor's. the ESC works for a few runs before i discovered, could that damage the ESC and the diode?
Because the ESC is still working, can i assume that the ESC is still working properly? otherwise i have to order another one.
#1589
I presume low frequencies but how low? Start at 4.57kHz + for mod??????
Heibeki? Someone Anyone?
#1590
Originally Posted by stinkypop
What sort of profile would you use for off road that is my question?
Go to KOpropo.com and there are off road 2wd and 4wd profiles
