Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 12-06-2005, 04:30 PM
  #1561
I'm pretty sure that is right. I could be wrong. Which esc are you using? VFS-2000 or VFS-1? Last I checked, it worked this way with the VFS-2000.
KO PROPO Staff is offline
Old 12-08-2005, 07:56 PM
  #1562
BritRacer's Avatar
ok vfs-1 gurus
I run a roar stock in sedan on a high speed carpet track with foams.
I probably let go to 3/4 throttle about 3 turns, and 1/2 throttle for 1 turn, the rest is full welly.
would something like this be a good start
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
4
5
6
7
8
9
etc
with a current limiter set at 26?
i dropped current to 12 and had way less rip.
or could you reccomend a profile with high speed, but mid punch.
BritRacer is offline
Old 12-09-2005, 12:51 AM
  #1563
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by BritRacer
ok vfs-1 gurus
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
4
5
6
7
8
9
etc
Brit, you have it backwards. you want lower numbers (lower drive freq) for more punch.
try something like
5
5
4
4
3
3
2
2
1
1
1
1
1
1
1
1
2
3
4
5
... etc
also try using a throttle response of "1" or "2" if you are smooth on the throttle. helps maximize the powerband. if your choppy with it, on and off, keep it off.
Hebiki is offline
Old 12-09-2005, 06:10 AM
  #1564
BritRacer's Avatar
ok, makes sense.
So starting with 4 it would have less punch from zero, but when laying off teh throttle a little, would have mid corner punch??
What would the effect be if i ran "1"s across the board??
Also, what if i turned the current limiter off?
Old 12-09-2005, 09:42 AM
  #1565
Current limiter off- all of the esc profiles that I have looked at have the current limiter off. For racing you want all of the ponies available. The current limiter is your index finger. We all have great throttle control, right?
Charles is offline
Old 12-09-2005, 09:49 AM
  #1566
"i dropped current to 12 and had way less rip."
I could not find a setting of 12, what do you have current limiter actually set at?
Actually I think current limiter setting of 12 = off
Read back a few pages and you will find a listing for those of us that don't have a poor windows system (Apple Rocks)and use a text editor to open the files.
Charles is offline
Old 12-09-2005, 10:50 AM
  #1567
Nathan Parker's Avatar
No left thumb
Nathan Parker is offline
Old 12-09-2005, 12:52 PM
  #1568
I have a Hara Twister 2.1 and plan on using it for mod foam racing(8T V2) is it essential that I install a fan before running mod or just wait and see if I have a problem? I will be racing indoor carpet.
slow is offline
Old 12-09-2005, 02:29 PM
  #1569
Alex C's Avatar
Trader Rating: 50 (100%+)
Charles,
Actually 12 = 120 Amps
There are 12 different settings(40-260A) plus an off.
An excessive current can be prevented from flowing to the motor by controlling the maximum value of the current. The current limiter setting in the VFS-1 can help to protect the motor and the battery.
I hope this helps Charles!
Best Regards
Alex Cortez
Alex C is offline
Old 12-09-2005, 04:58 PM
  #1570
Hebiki's Avatar
Originally Posted by Alex C
Charles,
Best Regards
Alex Cortez
alex.. i was wrong on that assumption. 12 does not equal 120... see robert's quote below:
Originally Posted by KO PROPO Staff
You are probably opening the file as a text document and the numbers do not correlate to voltage settings, for example 12=120A. The numbers do not work that way. If you insist on opening it with notepad, here is the reference.
0=40A
1=60A
2=80A
3=100A
4=120A
5=140A
6=160A
7=180A
8=200A
9=220A
10=240A
11=260A
12= OFF
If you have a doubt about the setting, use the PC software to open the file. It's FREE.
Hebiki is offline
Old 12-09-2005, 06:39 PM
  #1571
Alex C's Avatar
Chris....your absolutely right.
I was referencing the hand held programer!!
Best Regards Chris
Alex Cortez
Alex C is offline
Old 12-10-2005, 09:05 AM
  #1572
Appology accepted (12=120)
ACTUALLY Chris or was it KO Staff? straightened me out a few pages back.
Charles is offline
Old 12-12-2005, 09:30 AM
  #1573
TFR
TFR's Avatar
Ko Propo Staff,
Do you know where we could purchase these all black receiver wires? Thanks.
TFR is offline
Old 12-12-2005, 09:34 AM
  #1574
BritRacer's Avatar
its just black shrink wrap.
Old 12-12-2005, 09:36 AM
  #1575
Mr. Shookie's Avatar
Mr. Shookie is offline
