FDR for Chameleon 2? >
Old 08-16-2004, 02:38 PM
new92's Avatar
Default FDR for Chameleon 2?
Going to try my hand at 19T this points series as well as Nastruck.
The only motors the LHS had in was the C2. So one will go in the XRay and one in the L4. Since I have only run Monsters in the past I was curious as to any gearing differences.
I have heard gear them the same and go down a couple of teeth for the C2. Track is medium size asphault. Long back stretch....2 big sweepers.....carousel.....and 3 180s.
HobbyWorld in Jax, FL if anyone is familar with it.
new92 is offline
Old 08-16-2004, 02:47 PM
X2
X2's Avatar
Hi, I actually gear my Chameleon about 2 teeth higher than my monster and go from there, they do seem to be able to be geard quite high.
X2 is offline
Old 08-16-2004, 03:55 PM
DavidAlford's Avatar
Trader Rating: 32 (100%+)
I run a final drive of 6.16 in my losi with a our C2s. Great motors, lots of RPMs.
DavidAlford is offline
Old 08-16-2004, 08:03 PM
I was geared at 7.1 with my TC3 on rubbers, I should have gone up one more tooth then I was I had plenty of time left and the motor was just real warm, not hot.
And I too was geared HIGHER then my MS.
Smalls is offline
Old 08-16-2004, 08:22 PM
I forgot to say that was on a track about 150x60 with rubber tires.
Old 08-17-2004, 01:10 AM
ottoman's Avatar
I ran mine at 6.65 fdr in my MI2 with rubber tires... smaller track than David's. I think I could have went up another tooth on the pinion.
ottoman is offline
