sounds comming from my rear end >
Old 08-16-2004, 09:13 AM
Default sounds comming from my rear end
thiers a weird sound comming from the rear end of my tc3 i belive its comming from the diffs but i'm not 100% sure, its not like a whine its more of a deep sound but its very minimal what could it be?
kh15 is offline
Old 08-16-2004, 09:30 AM
Regional Moderator
UnderDaHill's Avatar
Had to laugh when I read your thread subject.
Anyways, it could be the diff, a bearing going bad in the diffs, the rear hubs, or the motor itself.
Try disconnecting the rear drive axles and running the car to see if the sound is still there. If so it's in the diff or the motor.
Try another motor. If you still have the sound it's in the diff. If it goes away it may have been the motor or possibly your gear mesh.
If it's the hubs just check for a bad bearing.
If it's the motor pull it apart and look at the armature. See if it shows any signs of rubbing the magnets when in use. Clean the motor and put it back together. Spin it by hand with the brushes out do see if you can hear or feel anything rubbing.
If it is the diff pull it apart and check all the bearings. Rebuild the diff exactly the way the manual says. Spin it by hand while out of the car to see if you can hear or feal anything rubbing or binding.
Just some ideas. Hope that helps.
UnderDaHill is offline
Old 08-16-2004, 09:32 AM
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Don't eat Chili Cheese Dogs (skyline) for lunch at the track. It's worked for me.
dr_hfuhuhurr is offline
Old 08-16-2004, 10:06 AM
my first thought when i read this title was...
try beano.
my second thought was... try a losi.
dae_paresh is offline
Old 08-16-2004, 11:10 AM
try beano.
LMFAO
Smalls is offline
Old 08-16-2004, 11:32 AM
Nrctc3's Avatar
Try it in parts... Just run the diff, then try a hub carrier then try the other hub carrier. Or just get a Xray lol
Nrctc3 is offline
Old 08-16-2004, 11:56 AM
Take the hole transmission apart (front and rear), and clean and oil the bearings, if a bearing doesen't spin freely replace it and rebiuld the diffs etc . If that doesn't help i don't know
Chazz is offline
Old 08-16-2004, 12:18 PM
try beano.
LMFAO
SINNER!
The Black Kat is offline
Old 08-16-2004, 10:43 PM
thanks guys and i think i'll stick to my AE its just as good as a losi or x-ray!
kh15 is offline
Old 08-17-2004, 12:59 AM
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
i get noise frommy rear end, usually accompanied with a smell sorry couldnt help myself
dontfeelcold is offline
