Who tapes the inside of their bodies? i >
Old 02-02-2011, 05:44 PM
*BBB*'s Avatar
Default Who tapes the inside of their bodies? i
I'm wondering if it will help keep the body from cracking as easy or any other adv/disadvantages..
*BBB* is offline
Old 02-02-2011, 05:57 PM
MikeXray's Avatar
Trader Rating: 73 (100%+)
TOP makes an aluminum tape that works very well.
MikeXray is offline
Old 02-02-2011, 05:59 PM
pejota's Avatar
Drywall tape and shoe glue
pejota is offline
*BBB*'s Avatar
Is aluminum tape the way to go? I'm that might reflect and create more heat?
*BBB* is offline
Old 02-02-2011, 06:19 PM
rc_square24's Avatar
+1 on drywall tape/mesh with shoe glue or other synthetic glue, really helps to keep the crack from spreading. Put it over the front bumper and top of wheel arches.
i also tape around the mount holes with fibre tape to prevent the pins from scratching the paint off.
rc_square24 is offline
Old 02-02-2011, 06:20 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
Generally no I don't except for 1/8th onroad bodies. There are spots that rub the body like the front bumper, rear body mount, etc. and scratch them all up so I put a bit of tape in those spots to prevent scratches.
Sometimes I might put a bit of fiberglass tape and shoe goo in the front fender corners to prevent or repair cracks.
wingracer is offline
Old 02-02-2011, 06:24 PM
I have actually been using a 1mm thick neoprene its kind of like wetsuit material. With some areosol adhesive it works great because it's moldable into every corner. Really keeps rocks n such from messing up an expensive paint job and helps keep the body from cracking. I do this on 1/5th scale bodies and suprisingly it adds very little weight.
LOST IN MN is offline
Old 02-02-2011, 06:57 PM
Trader Rating: 41 (100%+)
for preventing cracks and breaks mesh drywall repair tape and shoo goo then for possible rub areas just duct tape
jdeadman is offline
Old 02-02-2011, 07:33 PM
cheROK1212's Avatar
+1
cheROK1212 is offline
Old 02-02-2011, 07:50 PM
Trader Rating: 14 (100%+)
Racer tape....aka....duct tape. With the right application, a teddy bear will go 100mph when duct tape is applied by a pro.
DuckStang is offline
Old 02-02-2011, 08:28 PM
treborwd22's Avatar
I use drywall tape with SealAll from Home Depot @ 2.99 a tube.
treborwd22 is offline
Old 02-02-2011, 08:29 PM
Trader Rating: 29 (100%+)
Gyr0 is offline
Old 02-02-2011, 08:32 PM
Bonadona's Avatar
Trader Rating: 26 (100%+)
Drywall tape and shoo goo works but adds entirely too much weight that high up on the car. The TOP aluminum tape is the way to go.
Bonadona is offline
Old 02-02-2011, 08:54 PM
gtfour93's Avatar
Trader Rating: 22 (100%+)
Is this stuff much more stronger than Shoe Goo? I need something stronger for Short Course truck bodies.
gtfour93 is offline
Old 02-02-2011, 11:59 PM
BigDogRacing's Avatar
+1 That's a great tip Bondidondi!
BigDogRacing is offline
