Multiple power capasitors on brushed speed controls? >
Old 01-31-2011, 09:52 PM
J-VET's Avatar
Default Multiple power capasitors on brushed speed controls?
So Iv'e noticed some people running brushed esc's with multiple capasitors. Whats the purpose? I have a FX pro with 1 and a QC3 that doesn't have any. What is the purpose/benefit of one or more? 3-4?
J-VET is offline
Old 01-31-2011, 10:34 PM
If the caps are on the battery side, it helps reduce the ripple voltage going into the ESC and Battery. It just gives a steadier voltage for the ESC to run. Some say it will make the ESC run cooler, but i have honestly never run the ESC without atleast one.
Shawn68z is offline
Old 02-01-2011, 06:28 AM
J-VET's Avatar
So is 3-4 better then 1?
J-VET is offline
Old 02-01-2011, 11:10 AM
its not about the quantity of the caps, its about the voltage and capacity of the capacitor. You need a 16V to 25V capacitor, and technically the higher the capacitance you use the smaller the ripple voltage will be. I normally use a 470uF capacity.
I also run a capacitors on the BEC side of the receiver (known as a glitch buster), so when the servo requires a high current draw, the cap will keep the voltage up high. This stops the AMB and RXer from reseting from a low voltage dip.
Shawn
Shawn68z is offline
