Old 01-29-2011, 08:43 AM   #1
angry-alien's Avatar
Default XRAY T2/T3 SPOOL IN A T1 ???
Hi all... I am in need of some serious advise regarding the above subject... For some time I've been running a multi-diff setup as a spool in my T1...
the cars is whole lot of fun to run and there tons of power provided by the LRP system... The biggest issue I am facing is the destruction of the
3mm caps that are mount on the dogbones...
I posted this issue in the XRAY T1 thread: "i am currently facing is the constant failure of the 3mm plastic drive shaft caps... I am running a spool
up front... every time i make a run, the plastic caps go a away... anyone else having this experience? suggestions? fixes
This is the response i got: "I guess best bet would be getting T2/3 front plastic spool that doesn't use
blades. That would change your internal drive ratio and you would have to change rear as well. I guess there isn't any other option.
Now, I'm not sure if I dismissed this idea prematurely by saying the T2 and T3 parts won't work with T1's... It seemed to be a general problem
with the design... and I the think this is Xray's solution... Composite Solid Axle 34T - Set... the good thing about this spool is that the
drive ration won't change... Do you guys think this spool could fit in the T1? where can I find the measurement for this unit? see the below photo...
Any help will be appreciated
Alien
angry-alien is offline   Reply With Quote
Old 01-29-2011, 01:03 PM   #2
lochness42's Avatar
Aye, right with this spool IR will be the same.
I've just tried to fit 38T spool in my T1 car, unfortunately I've had only gear laying around without outdrives as I don't run Xray for quite a while and somehow this is still in my parts box. It seems to fit a bit tightly between bearingsl but I still was able to spin it. What might will be issue are outdrives itself as I don't know their outer diameter I'm not sure if they'll fit in the rings holding bearings.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-29-2011, 01:19 PM   #3
trerc's Avatar
Trader Rating: 89 (100%+)
It will not work it the T1
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-29-2011, 01:28 PM   #4
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
You could try to find one of these.
http://www.teamxray.com/teamxray/pro...%20T1M,%20T1FK
But it will not work for a FK05
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 01-29-2011, 01:44 PM   #5
BCbud's Avatar
I just relized you are looking for the plastic spools, dissregard my last post.
Recycled teenager.
Old 01-29-2011, 09:41 PM   #6
Well... here is the thing... since the 34 tooth pulley is available, I would now be only concerned about the fit between the bulkhead/bearings and alignment with the front belt...
could you post some photos of the test you made?
Care to elaborate?
No worries man...
Thanks for the quick response guys..
Alien
Old 01-30-2011, 04:33 AM   #7
lochness42's Avatar
Alien
Well I didn't have belt on as I had 38t version and belt wasn't long enough. As for pics - it will have to wait until end of week I'm afraid. I'm not at home for now, sorry.
Pavel Balint
Old 01-30-2011, 07:22 AM   #8
trerc's Avatar
care to elaborate
Sure... According to the XRAY cross reference guide it won't work. Why you ask? Because the spacing between the bulkheads isn't the same...
Old 01-30-2011, 10:23 AM   #9
I will wait for those photos... also can you take some measurements (bearing OD and width) so I'll be able to make some comparisons with the T1 Multi-diff...
Yes... I have the chart... but i wanted to know how much wider/narrower the the new diff would be... I wanted the numbers...
Thanks guys
Old 02-01-2011, 06:36 PM   #10
No other opinions??
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28982 12-04-2017 11:08 AM
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 02:07 AM
