Novak GTX
#571
Originally Posted by cvt01
The manual says that there is a 36Amp Shottky built in the GTX. I have an external Novak 36A shottky soldered on the ESC. Does it give any advantage or it is just extra weight in the car??? Can I make the wires of it at least shorter? I've heard or read somewhere that you should not cut the shottky's wires???? Does that make any sense?
Also the capacitor takes a lot of space do I need it when running 19T?
#576
Just use the #1 profile it's good all around on both 19T and stock. But then again I switch to brushless.
#577
Spanky, I would advise you to run the diode. I can tell you first hand without it, I'm pretty sure the back voltage when braking is causing a lot of extra heat, enough that components will start falling off the circuit board. Cost me a speed control, a servo, set of rear tires, a motor and one really tweaked car.
#578
Hey Gary, did you have it fixed for the WF Race? I never checked of asked you.
(for everyone out there, some people believe me to be nosy
#579
I was wondering if anyone had a good setup for the GTX when using a 27-turn motor like the Trinity Monster CO27 Pro? Is there a good custom one someone has done, or what is a good programmed setting?
#582
Thanks for the tips! Good to see you still around Kev.
