Novak GTX
Old 01-17-2006, 03:38 PM
  #511
Charlie's Avatar
The Quick Jump into the program mode is a bit tricky, If you can't get it to work, you can easily get to the adjustments by checking the profile, then taping the button during the final light "countdown".
The Power Cap cannot make voltage if it's not there. So it only goes to what the battery pack "is". It will slowly discharge as it sits by itself, so don't expect it to read much voltage after everything is disconnected.
Charlie is offline
Old 01-17-2006, 04:01 PM
  #512
EricO3's Avatar
So when i saw the spark from the where the Capacitor wire on soldered onto the ESC board (by accidentally hitting the flat-head type soldering tip on both neg/pos connections) it only discharged the copacitor and didn't ruin it, or it may have been discharged from not using it in two days already. As long as it went back up in volts when I soldered the battery on, it should work on and still have all the punch it had before right?
-Eric
EricO3 is offline
Old 01-17-2006, 05:15 PM
  #513
A capacitor stores energy. If you sparked it it discharged its energy and will work just fine again when you power up your car the next time. When a capacitor blows you will most definately know it, pretty loud and blows white fuzz everywhere.
JimMcClure is offline
Old 01-17-2006, 05:58 PM
  #514
Jack2's Avatar
Nah, Its not dead. If you disconnect the pack after a run and then turn the ESC on, the lights on the ESC should light up for a second, that just dumping the cap. It will read out at a low voltage but when you run the car again it will take a charge.
Jack2 is offline
Old 01-17-2006, 06:11 PM
  #515
EricO3's Avatar
Nice
lol, thanks!
-Eric
EricO3 is offline
Old 01-17-2006, 06:40 PM
  #516
Trader Rating: 17 (100%+)
Quick question
So the higher the # on the Minimum drive , the more initial punch you will have? If so wouldn't you want that for stock touring? The factory setting is 3 if your in program #1
H8W8IN is offline
Old 01-18-2006, 05:21 PM
  #517
anyone?
H8W8IN is offline
Old 01-18-2006, 05:58 PM
  #518
dakrat's Avatar
Originally Posted by H8W8IN
Quick question
wheel spin
dakrat is offline
Old 01-18-2006, 07:43 PM
  #519
stock touring car on carpet ....wheel spin...I dont think so
H8W8IN is offline
Old 01-18-2006, 08:31 PM
  #520
tc3blue's Avatar
Arrow
tc3blue is offline
Old 01-18-2006, 09:17 PM
  #521
dakrat's Avatar
dakrat is offline
Old 01-18-2006, 10:40 PM
  #522
asw7576's Avatar
I have GTX and GT7. Everytime I plug my GT7 to battery there is big spark. Doesn't happen with GTX.
asw7576 is offline
Old 01-18-2006, 10:57 PM
  #523
Ermm..I have them both,and they both spark??
But its normal...Maybe you would like to email to Novak for better answers?
Ben.C is offline
Old 01-24-2006, 03:40 PM
  #524
Well is there something special I should do? It doesnt seem like there should be any thing to it, just press the button twice quickly. If it doesnt work it shouldnt be listed as a feature.
AE Racer is offline
Old 01-30-2006, 10:18 AM
  #525
I apologise in advance because I am sure this has been asked before - but there are now in excess of 500 replies .........
Is there any advantage in fitting an external Schotky diode to a GTX running stock and 19 T motors?
Thanks!
exint2 is offline
