Old 12-28-2005, 08:03 PM   #496
Originally Posted by J FAST
Does anyone know if you can run the gtx without the power caps or is their a big difference performance wise.
thanks
If you don't run it with the caps on....It may void the warrenty also...
Best bet is to run the caps.It keeps the ESC run cooler also...
Ben.C is offline   Reply With Quote
Old 01-10-2006, 05:12 PM   #497
Mark G's Avatar
Send a message via AIM to Mark G
ok i am having some realy weird stuff hapen to my GTX its new and i just used it yesterday and it was fine and i changed motors and stuff and now wen ever i go to conect the last wire it gives power to the motor even tho its off. i maid check i have the wires corecrt pos wire to pos side of motor and pos side of the batt. blue negitive to the motor - side. lastly the black neg wire to the neg batt cell. I dont kno what to do
Mark G is offline   Reply With Quote
Old 01-10-2006, 06:01 PM   #498
Gael L's Avatar
I actually experienced the same thing with my GT7. What happened was that my wire came loose from the board on the GT7. Make sure the soldering is on firm.
Gael L is offline   Reply With Quote
Old 01-15-2006, 03:56 PM   #499
Mark G's Avatar
question one of my wires came out of the compastor is there any way to sodder it back into it ?
Old 01-15-2006, 07:51 PM   #500
ebone's Avatar
i run stock 1/10 what is the best set up for the gtx. also if neone has a rdx, where do you fit that big ass cap?
ebone is offline   Reply With Quote
Old 01-15-2006, 08:36 PM   #501
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Got a question about GTX/Radio "weirdness". I use Throttle Profile 1 and my Transmitter is a Futaba 3PK using HRS receiver. To stop the car from moving foward I have to put the Throttle trim ALL the way down, and even turn the sub-trim way down to stop it. Is there any reason for this? and more importantly, is turning the trim and sub-trim down restricting the top-speed of the car? Thanks!
-Eric
EricO3 is offline   Reply With Quote
Old 01-15-2006, 09:25 PM   #502
-Eric
Eric,
You may want to reset your throttle setup with the speed control - you should not have to trim-out your throttle response to eliminate the car creeping forward. I don't know about the 3PK, however, some radio's can limit full-throttle when you set your trim at the lowest point.
I would suggest that you re-program the speed control right from scratch with the trims set as per the instructions ... should get rid of your problems.
duckman996 is offline   Reply With Quote
Old 01-15-2006, 09:26 PM   #503
Nope ... that cap is now garbage.
Time for a new one.
Old 01-15-2006, 09:50 PM   #504
EricO3's Avatar
Originally Posted by duckman996
Eric,
How do you get the GTX back to the factory settings?
Old 01-15-2006, 10:10 PM   #505
The Evicerator
Eric,
Simply preform a one touch setup and it will return it to the factory default settings.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-16-2006, 09:32 AM   #506
EricO3's Avatar
Originally Posted by Evicerator
Eric,
Thanks, that ended up fixing my problem. Forgot to do that when I got the new radio, so now the trim is at 0 and the car doesn't move forward
Thanks!
-Eric
Old 01-17-2006, 12:29 AM   #507
I have a gtx and when Iam in the custom profile (profie 7), it will not go into setup when I push the button twice when not in setup mode. The manual says you can do this and I am sure that I am in profile 7. The only thing that happens when I press it twice is the red led flashes a few times and then it returns to the normal non-setup mode led configuration.
AE Racer is offline   Reply With Quote
Old 01-17-2006, 06:25 AM   #508
StasI's Avatar
i used the novak gtx for the first time today and ran very very smooth on setting 3 in stock class TQed but came 3rd in A main
thumbs up novak
StasI is offline   Reply With Quote
Old 01-17-2006, 02:05 PM   #509
EricO3's Avatar
Have a question about the Novak Power Copacitor, is it ALWAYS supposed to have 10V inside of it? I think i may have dead-shorted mine while removing the other wire to replace them. I tested it and it only shows .97V with nothing hooked up to it except the ESC (No Battery). Is it dead? thanks!
-Eric
Old 01-17-2006, 02:23 PM   #510
EricO3's Avatar
Update, just hooked up the battery and turned on the ESC, the Copacitor (SP??) read the same V as the battery, 7.93 volts (Not fully charged). I guess this means it works or what? Thanks!
-Eric
J Concepts BJ4WE CHEAP!!! NIP NOVAK 10.5 & Novak 4300 w/Sintered Rotor Zac R R/C Items: For Sale/Trade 15 02-13-2008 06:13 PM
LRP Sphere tc, Novak 13.5pro, Novak 10.5 pro, Novak 13mm rotor theisgroup R/C Items: For Sale/Trade 9 01-08-2008 11:21 AM
JR R1, Novak Smart Tray, Novak GTX, Futaba S9451, Hellfire stock motors, plus more yauipop Australia For Sale/Trade 7 08-27-2007 03:56 AM
For Sale Novak 3.5 brushless motor with Novak Heat sink $60.00 SHIPPED!!! Marcos.J R/C Items: For Sale/Trade 14 06-24-2007 08:29 PM
Rivergate RCD30, Novak Millenium Pros, XXX4G+, XXXTMF, lehner/novak BL Jman-x R/C Items: For Sale/Trade 1 09-14-2005 10:51 PM
