Novak GTX
Old 04-15-2005, 09:36 PM
  #436
RayWarner's Avatar
Hey I'm having a problem with my GTX. When I get tagged or if I miss my line and I smack a board the power to the motor goes dead. I still have steering but nothing to the motor. If I turn it off and back on it works fine again. Any ideas? Ray
RayWarner is offline
Old 04-15-2005, 09:39 PM
  #437
The Evicerator
If the one touch setup button gets depressed under normal opperation it will cut power to the motor for approximately 15 seconds. This loss of power will also be accompanied by the red LED flashing to indicate an "error"
I would recommend mounting your ESC so that the button does not face the outside of your car so that impacts like that cannot accidentally hit the one touch setup button.
Steve Weiss is offline
Old 04-15-2005, 09:43 PM
  #438
RayWarner's Avatar
I thought of this too but it isn't in a possition to touch or get touched. I had this in a 415ms and now in a RDX with the same problems. Ray
Old 04-15-2005, 09:44 PM
  #439
Default wires
check to see if all of the wires are broke on the board, tug on the wires to see if any of them come out, the input harness could be damaged
lickrim is offline
Old 04-15-2005, 09:48 PM
  #440
RayWarner's Avatar
Default Re: wires
That I will try. Thanks! Ray
Old 04-15-2005, 09:50 PM
  #441
Default scuba
dude are you running 19 & mod ?
lickrim is offline
Old 04-16-2005, 06:41 AM
  #442
Hardriven RC's Avatar
I had the same problem with one of my Cyclones years back. All it took was to open the housing and clean the electronics with a soft brush. Sand and debrid is sometimes conducting so that might be the problem/solution.
Regards
Hardriven RC is offline
Old 04-16-2005, 09:31 AM
  #443
I had this problem and it turned out to be my receiver.
The track where I race can get very dusty and the dirt that accumulated in my receiver was messing up the connection to my GTX, I took the receiver apart, blew out the dust and now it works fine
Dan Reynolds is offline
Old 04-16-2005, 09:37 AM
  #444
Could be that to.
Old 04-16-2005, 10:17 PM
  #445
RayWarner's Avatar
Thanks, I will check all of these things when I get a chance. I have run Orange Power since I've started and have NEVER had any problems. Bet it will turn out to be my error... Ray
Old 04-16-2005, 10:34 PM
  #446
duckman996's Avatar
Default Brittle GTX Case?
After being tagged by a back marker that I was laping for a 2nd time, I noticed that my speed control was knocked loose from my car ... such that the case cracked. Has anyone else noticed that the case for the GTX is more brittle then the ones on the GT-7?
Otherwise, I love the speed control - however, I am really picky about my equipment and I hate looking at a speed control held together with fiber-tape ... it's driving me nuts.
I'm going to contact Novak and see what I need to pay for a new case.
Thanks,
Martin
duckman996 is offline
Old 04-16-2005, 11:50 PM
  #447
mini-dub's Avatar
Trader Rating: 16 (100%+)
I haven't had a problem with the GTX cases cracking, but any esc case may crack if it dangled around and off the car during a race, it's good that it still works properly. I'm sure you can get it fixed by sending it in to Novak.
Just think, lots of people have to tape their quantum2 cases together when they were brand new to keep them from popping open without falling out of the car.
-WR
mini-dub is offline
Old 04-17-2005, 12:48 PM
  #448
Korey Harbke's Avatar
I haven't had any problems either. GTX has been a solid performer since the first day I put it in my car.
-Korey
Korey Harbke is offline
Old 05-21-2005, 07:04 AM
  #449
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Hey guys...
I'm new to orange power and just put one in my Pro4. I programmed it and it works great. But I wanna know, there's a red light on all the time and my PT's light is on too but when I squeeze the throttle both lights go out. Is this normal operation? -JB
JayBee is offline
Old 05-21-2005, 07:12 AM
  #450
Jack2's Avatar
Yep that sounds normal to me. It will also flash on and off if you get bad interference.
Jack2 is offline
