Old 08-11-2004, 11:29 AM   #1
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Single cell testing on Turbo CE
I have 2 CE turbo 35BL charger and a single cell holder but no directions/settings/clue on what is the best procedures for this.
The directions for the charger are not very clear and I do not have the manual/direction that the single cell holder should have come with....
Looking for help before I start "popping" cells ...
THX
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-11-2004, 01:52 PM   #2
OPTIONAL BATTERY BOX
To connect to the optional battery box, simply plug the battery box into the battery pack connector from the TURBO35. Then connect the small red alligator
clip to the small red lead on the battery box and the small black alligator clip to the small black lead. The small voltage sensing leads must be connected
to get accurate discharge readings. DO NOT hook up any extra wire to the battery box high current leads. This can cause the discharge current to
taper off at the end of the discharge.
Mount the end of the battery box with the springs to a flat surface with the holes provided. The other end of the box is left free to move. Do not tighten
the screws all the way, otherwise the battery box will not move freely.
The battery box may be forced open by squeezing the spring end of the rods and the box between the thumb and the forefingers. This is useful for placing
the battery in the box. The positive terminal of the battery goes to the red lead end of the battery box. Rotating the battery in the box will ensure good
connection between the contacts and the battery. To remove the battery, place your finger underneath the battery and push up.
The contacts used are tin plated brass contacts. The contacts can be cleaned using a model train track cleaner for brass tracks such as Rail Zip. They
should be cleaned twice a day.
For a single cell, follow the same procedure as for a pack except reduce all the settings for a single cell.
For example, use a peak detect of value of .03 volts for a single cell versus say .05 for entire pack. Otherwise, its the same. When choosing the number of cells, choose 1.
Everything is in the instructions and they are available online as pdf here: http://www.competitionelectronics.co...s/t35book.pdf.
Just read the entire manual and whenever is says, "single cell" highlight that section.
They should have created a seperate section for single cell but all the information you need IS in the manual.
If you need more help, just contact CE but everything is in the manual
LeadFoot is offline   Reply With Quote
Old 12-06-2006, 07:37 PM   #3
Trying it now after 2 plus years.... Using the cycle mode on somw old cells to make up some 4 cell packs...
RC Tech member #11
Turbo 35 GFX And Single Cell Holder BgHurt R/C Items: For Sale/Trade 7 10-24-2006 08:09 PM
CE SINGLE CELL HOLDER rogtsaamokin R/C Items: For Sale/Trade 3 09-11-2006 10:03 PM
Single Cell evaluation andrewdoherty Electric On-Road 2 09-09-2006 07:58 PM
CE Single cell holder II Fast R/C Items: For Sale/Trade 10 03-31-2006 04:31 PM
Single cell label..??? Speed Demon Electric On-Road 4 02-28-2003 08:11 AM
