Noob needs help!! PLEASE
Hi, I'm fairly new with R/C's. I just bought a new ezrun 9t brushless motor with ezrun 60A ESC. I installed it to my Tamiya with the ESC in the ch2 of my receiver. I was able to setup my transmitter with the ESC by following the instructions on the manual. My problem is that when now when I turn on the RC, the wheels would go all the way to the left, even when i trim the transmitter all the way to the right, the wheels are still towards the left a little bit. The Throttle is fine, it goes forward, brake and reverse. Another problem I have is when I steer the transmitter to the left, the car would move forward even when I have the throttle on neutral. I'm out of ideas. Please help.
Originally Posted by powerprogoose
(Post 8519195)
(Post 8519195)
Did you put the controle horn on while you had the servo on and trimed?. Also if you are using a tamiya esc then you need to set it. First press the red set button on the esc the red light should sart flashing. Press it again this will set the nutral trigger position next pull the trigger all the way down and press the red buton again, last push the trigger all the ay down on full brake/reverse and push the red button and the esc should be set. this should be the same as the intructions.So go grab the bag the esc came in and read the info. hope this helps:tire:
Originally Posted by Chaz955i
(Post 8519429)
Are you turning the car on before the transmitter? Could be the reason the wheels shoot to the side when powered up. As to the other problem maybe try setting all the steering and throttle trim and endpoints back to neutral, rebind the transmitter and start again. No idea why the car would move forward from steering unless the plugs aren't in the right spots in the receiver. Good luck.
Originally Posted by gtfour93
(Post 8519620)
This might be the problem. You need a 35A ESC, to match the 9T motor (3650M), or you need a .5 motor (3650) to match the 60A ESC. At least that's how Hobbywing offers their combo kit.
Originally Posted by racerdork
(Post 8519734)
He means the control arm that is on the servo. That is the arm that swings when you turn the steering. Take the servo control arm off of the servo, turn on the radio, turn on the car, reset your steering trim to 0, then put the servo control arm back on the servo so that the wheels are as close to centered as possible. Then you can use the trim to get the wheels the rest of the way to center.
Originally Posted by InspGadgt
(Post 8520468)
(Post 8520441)
What do you mean by control horn? sorry i'm really new to this. Yeah I did set up the ESC with the transmitter. Before setup the whole car just goes haywire (rapidly turning left and right on its own and car just goes back and forth without pressing anything on the transmitter.) After setup, the throttle is fine but steering is just always to the left and if I steer to the left even, it just makes the car go forward. I'm thinking it may very well be what gt says that I need 35A.
Before putting the horn on the servo, did you zero out your radio trims and actually turn the radio and car on so that the servo can center itself???
| All times are GMT -7. It is currently 11:00 PM. |
