exotek new chassis: cleanup screw holes
Hi there. I just got a Exoteck chassis (for a 2008/2008)
The screw holes on the top are raised a bit & need a cleanup before assembly.
I'd appreciate any input into the best way to do this.
Cheers
Cheers
If your using metric screws you need a 90 degree counter sink, sae screws then you need a 82 degree
Its not the countersunk side
its where the holes exit the top, around the holes exit its just slightly raised up.
Almost like a breakout burr ? (wrong term ?)
