Old 01-19-2011, 01:06 PM   #1
Cool How loud should my car be?
ive got an mi4 but the motors pretty knackered and i think its gonna pack in soon( im getting a new motor ) but it seems to be quite loud, much louder than my tt01 but this is my first racing chassis and my first beltdrive car and i want to know if ths is normal, it sounds like it comes from the spur and diffs
Schumacher MI4 is offline   Reply With Quote
Old 01-19-2011, 01:13 PM   #2
cyclone speed's Avatar
Before you blow it up or grind the diff/spur, check to make sure they are moving freely without the motor on, when checked and done, your car should sound quite silent, check any vids on youtube so that it gives you an idea
Its down to gear mesh, whats dp are you using ?
cyclone speed is offline   Reply With Quote
Old 01-19-2011, 01:34 PM   #3
Mikkel_R's Avatar
Not sure if the transmission on the MI4 Is the same as the MI4LP but when I built mine it started to make a bit of noise at full power, it turn out to be the grub screw on the pinion gear just catching the main drive belt. But as said above make sure it runs freely with no motor in as they should run fairly quiet.
Mikkel_R is offline   Reply With Quote
Old 01-19-2011, 01:38 PM   #4
housey's Avatar
Could well be a tight spur/pinion mesh. There should be a little play between the two.
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 01-19-2011, 01:38 PM   #5
Suspended
Trader Rating: 14 (100%+)
Should just hear the whine from the motor, maybe the rattling of the body as you drive.
Phatkat is offline   Reply With Quote
Old 01-19-2011, 01:46 PM   #6
thanks just loosened the mesh and its fine
Old 01-19-2011, 02:00 PM   #7
trerc's Avatar
Trader Rating: 89 (100%+)
Be sure to double check your mesh when you get your new motor or you'll "pack it in" prematurely too...
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-19-2011, 02:10 PM   #8
Foxxrocket's Avatar
Belt cars should be quieter than a shaft cars. Like Phatkat said, you should only hear the pitch of the motor and not much else.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 01-19-2011, 03:40 PM   #9
Suspended
Do this; cut strips of notebook paper(or any paper that is .002"-.005" thick) 1"-1.5" long and the width of a pinion. Stick 'em in your toolbox where they won't get all jacked up; a 35mm film can will do nicely. When you set mesh, put one between the spur and pinion, push 'em together to crinkle the paper(don't do it so hard that they cut the paper), then tighten the motor screws. Pull out the paper, and presto! Set mesh.
I did it that way for a while, then I just got good at doing it by feel. By feel, there should be just a tick(literally) between the gears. Also, rotate the spur to at least 4 different positions to check, as the spur can bend, go oblong, or otherwise be out-of-round. If it's too tight in one spot, try a new or different spur, or check the shaft and bearing it's on.
Old 01-19-2011, 03:50 PM   #10
Suspended
To add: Look over your gears for wear and damage regularly and often. Worn gears, even when set right, are louder, and don't sound "right". Look at the profile of the teeth, they should be symmetrical.
Old 01-19-2011, 04:07 PM   #11
housey's Avatar
Worn gears is a good point, check for any missing teeth. Just one missing tooth (even when its only 1 in 80) will make the car sound like a bag of nails.
Poweeeeerrrrr!
Old 01-19-2011, 06:18 PM   #12
SammyZ's Avatar
Trader Rating: 138 (100%+)
sounds like your from the UK?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 01-20-2011, 09:58 AM   #13
ye im from uk
How loud is too loud??? Cmjomaha Electric Off-Road 14 03-09-2011 03:33 PM
Z-Car 1/8 Buggy E-conversion GSMnow Electric Off-Road 96 12-14-2010 05:32 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
ARIZONA TOURING CAR RACERS rcracerdude Racing Forum 6536 03-06-2008 04:21 PM
