Elco power supply volt adj. problem >
Old 08-09-2004, 01:26 PM
rc_square24's Avatar
Default Elco power supply volt adj. problem
hi there,
i have a elco power supply that i just got which has a volt adjusting pot on the side of the unit.
as it was putting around 10 volts out i turned the not to the right which is supposed to raise the voltage as the arrow shows but the tihng increased up to a point and it started to drop really fast and now no power is coming out even when i turn it back to original pos. and the led wont comeon anymore. i monitored it with a voltmeter FYI
this supply was supposed to be able to put out about 13.8V as specs sheet shows
anyone know why this is happening?
thanks anyways
rc_square24 is offline
Old 08-09-2004, 01:30 PM
heres the same model
(v adj. where the white pot is next to output terminals)
Old 08-09-2004, 03:00 PM
I did the same thing. Its not broken, it has this automatic thing where it turns off if its put up too far. Wait for around 20 mins and plug it back in( make sure the arrow is at the same spot that it was originally in). The adjustment screw is very very sensitive, so do tiny adjustments.
rcguy2477 is offline
