LRP Pulsar 2
LRP Pulsar 2
I just received my Pulsar 2. Have question about delta peak. The default delta peak setting for GP3300 battery is 10mV current at 5.0A(Recommended settings from manual). I thought 10mV is for repeak use?
What do you guys set your delta peak on your pulsar for GP3300 charged at 6A?
OOps, I mix up by cell voltage and total pack voltage.
For those who want to know. Pulsar2 do not have 3 step charging. P1,P2,and P3 is just profile to save your settings.
Pulsar2 can change the charge current on the fly. I think we can use it as 3 step charge or 4 step charge on this function. Just have to change the charge current manually, if I'm not wrong.
the pulsar 1 can also do this you sjut have to do it manually with the plus button or sumthin its a good little feature
Also, does the P2 have a 30A discharge feature?
I bought it at rcmodel.
Nope, only 10A discharge.
Originally posted by Fuzzy
I set my LRP's delta peak at the lowest setting, which is 5mv. You don't want the 3300's getting to hot.
Whats the ambient temperature? Do you use a fan or something?
Thanks.
