USRCF1 Formula One national event! >
Old 03-28-2011, 07:55 PM
  #106
MantisWorx's Avatar
Trader Rating: 28 (97%+)
eventually i probably will but i want to get it on the track first and see how it performs and then make changes. there alot of unseen forces here! i know for sure that the shocks in this format will work and wont causing any handling issues. the motor placement ,gear dif, battery placement etc etc has to be sorted out.
MantisWorx is offline
Old 03-28-2011, 08:06 PM
  #107
mxrich's Avatar
That last pic told me a lot about the car. I think you are on track for what you are doing. Go get'em.
mxrich is offline
Old 03-28-2011, 10:59 PM
  #108
Pro10noob's Avatar
Maybe it is just silly but did you try the axles of the F201?
As this is also a F1 with IRS??
regards Roy
Originally Posted by MantisWorx View Post
shock tower and wing mount! bout to make some dogbones!
Pro10noob is offline
Old 03-29-2011, 06:52 AM
  #109
MantisWorx's Avatar
i got that figured out already! 18r dogbones are the perfect fit!! also that old saying "necessity is the mother of all inventions" is so true, i made some "flat" dogbones yesterday and it works perfect. i will post more pix later today, but the chassis is an actual roller now. now i have to piece the front together, make a better upper link mount for the rear and machine some hex adapters for the F1 wheels. should have all of that knocked off today!
Old 03-29-2011, 11:56 AM
  #110
MantisWorx's Avatar
its sitting on the ground! looks good with camber and toe in!
who has 104 parts in the US and in stock? i need kingpins, e clips and some other misc stuff.
Old 03-29-2011, 06:45 PM
  #111
snoopyrc's Avatar
What are you looking at for gear reduction? Are you going to put a spur on a hub like a TC3? Then your motor will be offset.
snoopyrc is offline
Old 03-29-2011, 06:50 PM
  #112
Nice ride!!! Any f1 coming out with direct drive, rotary dampers like the Awesomatix!!!! That would capture the essence of F1: exactly like the real F1s.......
bertrandsv87 is offline
Old 03-29-2011, 07:06 PM
  #113
MantisWorx's Avatar
no gear reduction, the gearbox is 3.25 which is perfect for either 17.5 or 13.5 boosted. i have been running the same ratio on my MWXFQ01. and if thats not enough i can run a 21.5 /4s since the chassis is going to accomodate two batteries. i was able to drive 30minutes last week on a 2200 mah pack. i could theoretically have a 30min+ main and switch batteries in a pit stop!
i have no intention on selling this, it is just a project for me. instead of messing with gear ratios just change motor/battery for track conditions. the batteries are only 15.00 and i have all kinds of motors lying around. AND infinite adjustability with the Tekin RS! my goal is to be able to run same exact compound front and rear. i also took a pair of rear SS Rides, narrowed them and fit them on front wheels. even with the toe in on my FQ i still could not get the balance, way too much front grip. i think that i will be able to find a balance with this setup. the national will be its debut, i plan to run at least one qualifier (hopefully all of them!) with this car.
Old 03-30-2011, 03:43 PM
  #114
MantisWorx's Avatar
found the rest of the parts i needed and ordered them, its close to completion. i decided to make the chassis two pcs so i can change the wheelbase on the fly and also lower the CG by 3mm:
Old 03-30-2011, 10:18 PM
  #115
Good luck on your project. The only question I had was : does the motor output shaft slip into a precut steel slot without the need for a grub screw to hold it? If so, motor changes would be very easy! Also where would a Nikko F1 chassis fit into your racing event? Keep in mind I have rubber tires, a ballistic 4.5R in there, and it weighs about 1408g !!! What is the F1 rubber minimum weight? I know it's a Nikko(with bearings), but it is fast , and I just want to have fun!!!!!!!
Old 03-31-2011, 07:51 AM
  #116
MantisWorx's Avatar
it uses a grub screw on both ends so its not going anywhere and motor changes are very easy, no adjustment and two screws. the Nikko can run but until i see it i cant tell you what class, with that motor it will be Formula one more than likely, in fact if you are running rubber it will be formula one.
Old 03-31-2011, 09:23 AM
  #117
Old 03-31-2011, 09:46 AM
  #118
Angry
Here it is:
Old 03-31-2011, 10:07 AM
  #119
MantisWorx's Avatar
no minimum weight, only mechanical restrictions in teh formula one class are that it must have Tamiya/RIDE style wheels(no 10th pan) and rubber tires. no point in having a weight restriction with no power restrictions. why the mad face?
Old 03-31-2011, 10:44 AM
  #120
Can't upload pictures here!!!!!!
