Old 08-18-2004, 11:48 PM   #16
Trader Rating: 16 (94%+)
I typically charge my NiMH AAs at 1C, so 2300mah = 2.3A, and they dont even get hot, only slightly warm to the touch...
domo is offline   Reply With Quote
Old 08-18-2004, 11:48 PM   #17
Super Steve's Avatar
Send a message via AIM to Super Steve
well, there are 1 hour chargers made by raovac, energizer and etc...
So technically, you should be fine charging at 2.3 amps
I charge my sanyo 2300mahs at 1.5amps
Super Steve is offline   Reply With Quote
Old 08-19-2004, 12:54 AM   #18
nick51's Avatar
Send a message via AIM to nick51
are AA nicds any good? and my yokomo only lets me go up in 10's for peak m/v, so would 10 be fine at like .5amps
nick51 is offline   Reply With Quote
Old 08-19-2004, 10:56 AM   #19
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
thanks for the replies, it really helps!
marvi: I may steal them and use them in my RC car, in that case would it change your answer about cycling them?
corvettecrazy is offline   Reply With Quote
Old 08-19-2004, 06:40 PM   #20
Does anyone know if they make a 1.5 volt AA rechargable battery yet.....or are we still stuck with the way underpowered 1.2volt ones.........I'll take 12+volts of power in my radio anyday, over the 9.6volts you get with the 1.2 volt rechargeables, reguardless of how long they last.
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 08-19-2004, 08:17 PM   #21
Joel Lagace's Avatar
there have been rechargable 1.5volt alkalines out for a few years now. Most major brands make them. I see them at Walmart and Canadian tire. Not sure why you would want them when 1.2v nihms do the job so well and last for ever
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-19-2004, 08:18 PM   #22
j240z's Avatar
What do you use to solder the cells together? Does someone make battery bars for AA size cells?
j240z is offline   Reply With Quote
Old 08-20-2004, 12:56 AM   #23
Why wouldn't I want 1.2 volt cells..........We'll Joel....In "some" cases, the difference in overall voltage were talking about here...."can" make a difference in whether or not you get glitches or interference, especially if you race at tracks that have less than Ideal surroundings....I like to be as far away from interference as possible......not to mention that when I sent airtronics an e-mail concerning this some time ago......they replied that most highend radios (including theirs) were originally designed to perform best and most trouble free ,with 1.5volt cells.......I used to run 1.2volt rechargeables for a short time,but got tired of hearing the low voltage alarm beeping at 9.1 volts.....I'll have to check out some of the 1.5volt rechargeables you mentioned that they make............
Old 08-20-2004, 01:10 AM   #24
nick51's Avatar
i can get some nicds that are 1.5v, but are nicds any good, could i just use my trinity equalizer to discharge them?
Old 08-20-2004, 07:47 AM   #25
Sounds good to me. I guess i have never had that problem. Been using my 3PJ for years and have never heard the low battery alarm. I have raced at various tracks both electric and nitro. The only place i could honestly say i had glitching that could not be explained was in Cleveland during practice that mystiriously went away the next day... I dont doubt the high end radios would need the extra juice. But if your running high capacity 1.2v cellls you should rarely hear the low bat signal...
But like is said above 1.5v rechargables are available in alkaline and nicad as someone just mentioned
www.rcottawa.com
Old 08-20-2004, 11:05 AM   #26
guys I got a 4 AA battery thing, soldered some wires on there to connect to the charger and then charged them up.
My question is that the charge complete thing came up when there was only 178? mAh charged.
The other thing is that when charging the charger shows volts. it went up to 7.something(low 7's) but with 4 AA it is only a 4.8 volts pack. Maybe I am missing something. Charging at 1 amp it took 1:4?:?? is that about right?
i am leaving for most of the next week in 2 hours so if you ask a question and I dont reply until then its because I do not have computer access (grandmas house)
thanks for all your help so far, (and any future help)
Old 08-20-2004, 11:14 AM   #27
donoman's Avatar
Send a message via Yahoo to donoman
Hey dude, are you sure your batteries were not already charged before you charged them, and that is the cause of the low numbers?
donoman is offline   Reply With Quote
Old 08-20-2004, 11:34 AM   #28
forty6's Avatar
You can use a copper solder braid or solder wick. It comes in a small spool so you can cut to length. It is mainly used for "wicking" excess solder. You can find it a Radioshack or any electronics store. It is not expensive.
forty6 is offline   Reply With Quote
Old 08-20-2004, 12:08 PM   #29
j240z's Avatar
OK, thanks. I was looking for that stuff but couldn't find any. I'll try Radio Shack online. I've been wanting to make an extra TX pack!
Old 08-20-2004, 12:12 PM   #30
they may have had some charge in them. Not enough for my digital camera to turn on through.
Mugen 2300mah NiMH 5cell receiver pack PowerHouse R/C Items: For Sale/Trade 4 11-16-2007 09:34 PM
Questions about NiMH/NiCD Batteries rcnewb2004 Electric On-Road 2 10-10-2007 01:11 AM
NiMH 2500 mAh AA rechargables for Radio Centerline Racing Electric On-Road 6 12-01-2006 11:52 AM
charge? 2300mAh taj Electric On-Road 3 02-14-2005 04:01 AM
Nimh Care questions (NEED HELP!!!!!!) racerdx6 Electric On-Road 13 04-27-2003 01:58 PM
