Old 08-08-2004, 09:55 PM   #1
Send a message via AIM to micros_rock
Default Removing Motor Bushings?
Quick question: what's the easiest way to remove the bushings from the motor can and endbell? Thanks.
micros_rock is offline   Reply With Quote
Old 08-08-2004, 10:04 PM   #2
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
By using center punch tool that is larger than the bushing hole and tap the bushing out gently with a hammer.
g_bruin is offline   Reply With Quote
Old 08-08-2004, 10:06 PM   #3
I used a bit of thin dowel (?) and a spanner and knocked it through. The one in the can was really hard to get out.
Brad in Perth is offline   Reply With Quote
Old 08-08-2004, 10:35 PM   #4
tornado
Guest
Posts: n/a
Get a motor bearing remover mate! You just screw that sucker out safely without risking bending ur motor can by whacking it out. You could gently tap in the new bushing with a hole puncher using a hammer.
Bryan
Old 08-08-2004, 11:32 PM   #5
Tek Nickal's Avatar
This is my trick, get a pencil, sharpen it, stick it in the hole and tap on the end of the pencil and the bushing will come out easily.
Tek Nickal is offline   Reply With Quote
Old 08-09-2004, 12:10 AM   #6
Neil Rabara's Avatar
It's not that hard to do. The hard part is putting in the new ones strait and not at an angle.
Neil Rabara is offline   Reply With Quote
Old 08-09-2004, 12:31 AM   #7
Bryan
Where can I get one of those?
Old 08-09-2004, 12:53 AM   #8
tornado
Guest
Posts: n/a
Try here : http://rc-mushroom.com/index.php?cPa...sort=1a&page=5
Bryan
Stock motor Bushings!! baw888 Australia Wanted to Buy 0 04-01-2008 04:31 PM
Swap Motor Bushings for Bearings Jake S Electric On-Road 12 03-21-2007 11:28 PM
Stock Motor Bushings... XMSRacing Electric On-Road 5 02-11-2006 12:31 PM
Pressing bushings back into stock motor Still Bill Electric On-Road 4 07-10-2004 11:03 PM
bushings? SPC Racing Electric On-Road 7 03-06-2004 06:14 AM
