Mission Impossible??? >
Old 08-08-2004, 05:17 AM
wolfracing's Avatar
Help, my bloody Mission is becoming a real hand full, running ss5800 23t pinion 86t spur, soft rear grey springs the softest, laid down shocks in most horizontal position,(to try to get more traction down) front stiffer with red springs , shocks in mid position. (to get less) TO 22's on rear and TO 27's on front.
Set up is standart to the insruction book set up sheets.
Car is getting to much off pwr turn in and becomming unstable and on pwr over steer, ie wants to break away and get loose.
Hard to drive, car is quite fast in a straight line and on sweeping turns. tough to drive on twisty bits which our track is. Also very cold down here in Tasmania.
Any suggestions would be much appreciated.
Matt
wolfracing is offline
Old 08-08-2004, 10:25 AM
First you may want to tell us if it's a mission 1 or 2.... second is your tire/insert combo the same as the fast guys?? Are there many scratches/scrapeson the leading/trailing edges of your chassis?
If the tires/inserts are correct.... and no chassis scrapes....you can try...
More front droop
Less rear droop
return the shock set-up to stock settings and retune agian, maybe 1 step softer springs from stock (you may be way too soft)
IMPACTPLAYR is offline
Old 08-08-2004, 11:27 AM
John_S's Avatar
it looks to me that your rear end is to soft and possibly bottoming out you should try some setups from the schuamcher site http://www.racing-cars.com
John_S is offline
Old 08-08-2004, 12:09 PM
You might want to post to the Schumacher thread as well. All the team drivers hang out on that tread
LeadFoot is offline
Old 08-08-2004, 01:22 PM
Wency_TA03R-PRO's Avatar
Exclamation
More front droop
Less rear droop
This is a good pointer for you wolfracing to check it out.... so that you will know what might be the problem....
Wency_TA03R-PRO is offline
Old 08-09-2004, 04:48 AM
wolfracing's Avatar
Thanks guys, just had a look at the rear end of chassis, alot of scrapes, to soft. I'll go back to the books set up and work from there, tyres and inserts are matched.
matt
Old 08-09-2004, 04:51 AM
wolfracing's Avatar
oh yeah, its a mission 1
Old 08-09-2004, 08:49 AM
Exclamation
wish you get a positive result on that!..
Old 08-09-2004, 09:02 AM
TimPotter's Avatar
Trader Rating: 14 (100%+)
Wolf, like IMPACTPLAYR, also look at droop. As John S said, check out the setups on the Schumacher site. When I ran the Mission, most of my Asphalt setups were all blue springs, or a combination of blue-reds
TimPotter is offline
Old 08-15-2004, 05:25 AM
wolfracing's Avatar
Went back to box set up, now apears to be dialled.
Thanks guys
Wolf
