Old 08-07-2004, 12:37 PM   #1
Trader Rating: 16 (100%+)
Default AE #611 Reedy Quasar Pro Charger cannot charge 8 cells with more then 1.0 AMP?
I've got my AE #611 Reedy Quasar Pro Charger back from AE after their recall and got updated to Version 2.1....so far so good...cause I don't usually charge my receiver pack (8 cells) with more then 1.0AMP..........but recently, I just found out, the charge cannot charge 8 cells with more then 1.0 AMP....not even 1.1amp...
Can someone tell me that is the SAFETY issue or my charger need another RECALL or REPAIR from AE again...?
I emailed AE pertaining to the above question and will see what they will say.....but what about ppl in this forum....? The same issue or I am missing something...? Thanks....
P.S....for a $180 charger, that cannot charge 8 cells with more then 1.0 amp, that is BS.....
Old 08-07-2004, 03:53 PM   #2
j240z's Avatar
I personally don't have the Quasar but I've heard of people having this same problem after getting their charger back from recall service.
Looks like it's time for v3.0.....?
j240z is offline   Reply With Quote
Old 08-07-2004, 04:45 PM   #3
kufman's Avatar
My friend noticed the same thing about his charger. They may have changed it on purpose for some reason or another.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 08-07-2004, 05:36 PM   #4
Send a message via AIM to rcguy2477
Ive heared that this was for safety. Personally, I have been holding off on the recall because of this.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 08-08-2004, 06:07 PM   #5
Chris08527's Avatar
same thing happened to me, i thought my rechargables just went bad . . .
HMMMMMMMMMMMMM
Chris08527 is offline   Reply With Quote
Old 08-08-2004, 06:15 PM   #6
If you're running drag, I could see how this would be a problem. But for transmitter packs..... how much juice is your transmitter using? I mean, it's probably alright to run it with 1/2 charge, especially with aa's topping 2100 mah. We used to tough it out with 600 mah nicads back in the day
071crazy is offline   Reply With Quote
Old 08-08-2004, 06:22 PM   #7
Tek Nickal's Avatar
Hmm, I charge my 8 cell transmitter pack at 1/2 - 1 amp, I don't see why this is too much of a problem.
Tek Nickal is offline   Reply With Quote
Old 08-08-2004, 10:04 PM   #8
Simon K's Avatar
Just curious, on the Quasar box does it say how many cells it will charge?
Assuming it says "4 to 6" or something like that, then the fact it will charge 8 is only to allow for tx packs and 1 amp is adequate for AA's...any more may well be getting into that "dangerous" bit someone mentioned.
Simon K is offline   Reply With Quote
Old 08-08-2004, 11:20 PM   #9
Espiritus's Avatar
Says in the 2.1 manual "Maximum charge rates: 4-6 cells = 6.5 amps, 7-8 cells = 1 amp."
Espiritus is offline   Reply With Quote
Old 08-09-2004, 10:50 AM   #10
OK...thanks guy, so now I know it is not a individual case.....it is probably a DESIGN issue...
No, I don't have to charge my 8 cells AA with more then 1 amp, but I am just wondering will I have the option to charge 7 or 8 cells for more then 1.0 amp....
Thats cool.............
Old 08-10-2004, 06:13 AM   #11
Simon K's Avatar
It's not an "issue" as such...it's just the way the unit is set to function.
Old 08-10-2004, 08:52 AM   #12
Yes, got the respond from AE, they said it was "part of the fix"....so, I think I just can't charge my receiver pack more then 1.0amp.
Reedy Quasar Pro charger straightaway R/C Items: For Sale/Trade 0 08-13-2007 11:16 PM
REEDY QUASAR PRO CHARGER VER 2.1 cbl R/C Items: For Sale/Trade 5 04-04-2007 04:59 PM
FS Reedy Quasar Pro Charger v.2.11 Iceracer R/C Items: For Sale/Trade 12 03-18-2007 07:41 PM
WTB Charger that will charge 12 Cells stimcon R/C Items: Wanted to Buy 0 10-29-2006 06:05 AM
F/S Reedy Quasar Pro Charger FastFred68 R/C Items: For Sale/Trade 2 12-12-2005 05:14 PM
