got it!
Old 08-06-2004, 07:37 PM
Default got it!
i got my new tc3 a couple days ago and i love it!, but i have a few questions,
when i accelerate the car seems to wobble a bit and turning i seem to lose front end traction how can i fix this?
i was thinking about getting some springs because i lot of pros who i use thier setup sheets to better set up my tc3 for asphalt use diffrent springs than stock?
any other stuff i should know would be good to thanks
kh15 is offline
Old 08-06-2004, 07:57 PM
pheyhoe's Avatar
try standing the shocks up more at the front.
check all camber and toe in toe out is equal side to side. that is probably what is causing the wobble under acceleration.
another thing it may be is torgue steer, i get it all the time with my SD
pheyhoe is offline
Old 08-06-2004, 08:00 PM
TL_XXX-S_racer's Avatar
to take the loseness in the turn u soften the rear springs. Doing this will make more weight transfer to the rear witch means more rear traction.
TL_XXX-S_racer is offline
Old 08-06-2004, 09:32 PM
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Re: got it!
Get yourself the XXX Main Chassis Set-up Guide. ( I feel like I'm a promoter or something ).
- jAYbee
JayBee is offline
Old 08-07-2004, 12:14 AM
Neil Rabara's Avatar
That's good advice for the TC3.
Neil Rabara is offline
Old 08-07-2004, 12:37 AM
AdrianM's Avatar
Barry Baker's 2002 Reedy Race setup is the Standard Team Setup. That's what is on an Associated drivers car when they show up at a new track and is usually about 95% perfect. Go to www.rc10.com, download it and follow it EXACTLY. Get whatever parts you need to duplicate the setup.
AdrianM is offline
Old 08-07-2004, 10:00 AM
Wency_TA03R-PRO's Avatar
Exclamation Re: Re: got it!
- jAYbee
not bad bro!! helping newbie are one of the reason why these thread/forum exist.. keep it up bro!..
Wency_TA03R-PRO is offline
Old 08-07-2004, 05:22 PM
Default Re: got it!
EASE onto the throttle....You really can't jam the throttle on a TC3
TC3 is the most "stereo-typical" shaft-like shaft car I've ever driven....best handling too
The Black Kat is offline
Old 08-07-2004, 07:26 PM
onebeatuptc3's Avatar
i love the handling of my tc3, it just seems to like the wall alot more then me :P My car is set up so that my front is really stiff, and my back is stock. Im running copper up front and a sway bar, and it handles great. As for torque steer, i only notice it if i am trying to go completely full throttle after trying to get out of a crash or a slow turn.
onebeatuptc3 is offline
Old 08-08-2004, 02:03 PM
Maybe you're running your car in your garage try to run your car in a wider/bigger area so that you can run it in FULL throttle..
same here black kat.. l just seen you car on the other thread what other hop-ups have you made in your car?. just want to know your upgrades on your kit.
Old 08-08-2004, 03:17 PM
Hehe...Thanks for the interest Wency
Blue Aluminum:
Front brace for the rear hingepins
Steering Rack
Spur Adapter
Version 2 FT Main Shaft
Other:
RPM Front Bumper
RPM Ball-cups
MIP Steel CVD's up front
Rear Tower up front
All flathead 4-40s are Stainless Steel
Z-Racing Aluminum Servo Mounts
Z-Racing Hardened Steel Hinge-pins
Electronics:
LRP IPC v7.1, JR XS3 Radio system, Airtronics 94359Z Servo & GP3300's
Tires: CS-27 in the front...Either CS-27 (outdoor) or CS-22 (carpet) in the rear
I run BP motors and BS Bodies (Borrowed Power and Borrowed Shells)
Old 08-09-2004, 09:21 AM
Exclamation
what upgrade have you done on your steering rack? I just covered mine.. what's the diff between the rpm ball cups compare the the stock one?.
