silver can motoer >
silver can motoer
silver can motoer
Old 08-06-2004, 07:49 AM
wig
Default silver can motoer
how do you get a new silver can motor to scream?
wig is offline
Old 08-06-2004, 08:47 AM
burbs's Avatar
what kind of motor is it??? what kit did it come with more info is needed.. there are hundreds of silver can motors since time began..
burbs is offline
Old 08-06-2004, 08:52 AM
raving-monkey's Avatar
i am guessing he means that standard 540 you get with tamiyas etc..or the reedy spec silver can.
raving-monkey is offline
Old 08-09-2004, 06:12 AM
wig
the 540 motor that comes in tamiya kits
wig is offline
Old 08-09-2004, 07:17 AM
Throw it out of a plane at 50K feet. It will be screaming right before it hits the ground.
Smalls is offline
Old 08-09-2004, 07:27 AM
Wency_TA03R-PRO's Avatar
Exclamation Re: silver can motoer
I really don't know how to answer your question?. what do you mean SCREAM?!. Please do rephrase the question and be specific!. If it comes with the tamiya kit yup its a 540 johnson stock motor...
Wency_TA03R-PRO is offline
Old 08-09-2004, 03:48 PM
dsrbltoys's Avatar
put two of them together and try running them with 14.4 volts like in my txt-1. They really throw the sparks
OK, So you want that motor to go fast listen carefully. DRIVE carefully, Keep the momentum up.
What car is it in, sedan, mini, or what???
dsrbltoys is offline
Old 08-09-2004, 04:01 PM
Trader Rating: 30 (100%+)
There are a million ways to get the motors to go fast. water dipping. Bushing buster....blah blah blah. Prolong on the comm. Gear it to Pluto!
racenut123 is offline
Old 08-09-2004, 05:52 PM
dsrbltoys's Avatar
Maybe some of the old johnsons. Not the current batches... Too many different versions of the johnson/mabuchi motors to lump into one type of motor hopup.
look at the brushes. Are there two points, or three points where the brush seats against the com. On the back of the motor, are there four square cutouts, or four pyramid shaped cutouts?
Old 08-12-2004, 07:04 PM
Team Duratrax's Avatar
Gear it up high and run it on 7 cells.
Team Duratrax is offline
Old 08-13-2004, 04:21 AM
this is one of the key factors.....
