Closed Thread
Old 08-10-2004, 09:35 PM   #121
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default 200+ mph tether
ok found the link its towards the bottom of the page.have fun
http://www.radiocontrolzone.com/cars/video.asp
Steven
crACkeD ChaSsiS is offline
Old 08-10-2004, 09:36 PM   #122
dracy69's Avatar
Send a message via AIM to dracy69 Send a message via Yahoo to dracy69
seen that one before.vgotta make one of those r/c if at all possible
dracy69 is offline
Old 08-10-2004, 09:38 PM   #123
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
it says the cars are on wires???? then they cant take fight.. different ball game.. the wire helps keep them down
burbs is offline
Old 08-10-2004, 09:39 PM   #124
dracy69's Avatar
true but still
dracy69 is offline
Old 08-10-2004, 09:47 PM   #125
Default 200MPH TETHER
SO WAT U GUYZ THINK? ITS STILL DID 200MPH NO MATTER HOW U PUT IT!IT WENT 200MPH+ IM SURE.
Old 08-10-2004, 09:50 PM   #126
burbs's Avatar
right i admit it did and it is fast.. but with real rc cars they take flight .. they cant handle the air .. those cars say 600 pounds of air wieght on them.. so the wire helps that.. but in the case of real rc cars it just isnt there... thats what i meant
burbs is offline
Old 08-10-2004, 09:50 PM   #127
ajg
Registered User
ajg's Avatar
Burbs, do you like being wrong, because you are once again. The tires can't be too small, it doesn't matter what size they are. And if you scale down to a 1/18 scale, it will be lighter, which means a higher top speed.
My tires are 1.375 inches in diameter. My pinion is 31 tooth, and my spur is a 58 tooth.
Also ,do you have mental problems? Because I said I didn't get the stuff today so I can't make a video. So why don't you just wait till I get it, so you can say all your stupid stuff!
ajg is offline
Old 08-10-2004, 09:57 PM   #128
Default KEWL BEANS
KEWL BEANS
Old 08-10-2004, 10:02 PM   #129
burbs's Avatar
because i want u to do it right.. i dont have mental problems man.. if i wasnt right u would get so upset.. im not calling u names.. im simply staing the facts.. and yes tire sizes matter a ton..it effects your final drive ratio.. which is what we use to calculate higher and lower speeds or gear ratios..... dont argue when u dont know..
if u had any clue how important a final drive is u would understand... but by the list on your sig u dont have any real race vehicles.. u have basher toys.... so u dont know....
tire diameter X 3.14 = X
sur divided by pinion = Y X divided by Y equals you final drive
if u have a transmition that dirive is added in to ...
1.375 X 3.14 =4.3146
58 dividede by 31 = 1.870
4.3146 divided by 1.870 = 2.30
your final is 2.30
now lets do this......
take a 10th tire at 2.30 size..
so we have
2.30 X 3.14= 7.22
58 divided by 31= 1.87
7.22 divided by 1.87 = 3.86 final drive
2.30 or 3.86 which is a higher final drive?????? thanks next
burbs is offline
Old 08-10-2004, 10:04 PM   #130
ajg
Registered User
ajg's Avatar
Who cares? A micro is much lighter, so it can have a higher top speed. You proved nothing.
ajg is offline
Old 08-10-2004, 10:06 PM   #131
burbs's Avatar
see u just answered my question.. weight has no part in it... if u cant gear it right it wont be as fast...
you will see when its all said and done and if your so called stuff on the way ever gets here... then u can say im sorry burbs,, you were right...
not trying to bash you but YOUR WRONG......
burbs is offline
Old 08-10-2004, 10:08 PM   #132
burbs's Avatar
do this get two bikes with the same gearing one lighter then the other....
run the heavy one in the top gear and see how fast u go..
then take the lighter one and put it in a lower gear.. and see if u can go faster u cant.. u just pedal faster but no speed...
burbs is offline
Old 08-10-2004, 10:08 PM   #133
ajg
Registered User
ajg's Avatar
How am I wrong, my car IS geared right. So what are you trying to tell me, that you can do math? And weight has a ton to do with it.
ajg is offline
Old 08-10-2004, 10:09 PM   #134
Super Steve's Avatar
Send a message via AIM to Super Steve
the fact that tether cars can do 200mph has nothing to do with rc cars...
AJG, you are using full subC batteries?
Super Steve is offline
Old 08-10-2004, 10:09 PM   #135
ajg
Registered User
ajg's Avatar
Did you try it? How would you know.
ajg is offline
Closed Thread
Hauler bag that holds everything? platinumjason Rookie Zone 6 06-09-2007 09:18 PM
Speed Record 104 mph Drag Car b4maz Electric On-Road 9 04-04-2007 09:45 AM
"Official" Speed Record 134.4mph XrayFK Electric On-Road 14 08-09-2006 05:00 AM
elec car speed record rx3dreams Electric On-Road 12 08-03-2006 01:01 PM
speed record HELLION Nitro On-Road 5 08-23-2004 11:19 PM
