who holds the speed record? >
Old 08-16-2004, 03:58 PM
  #346
ajg
Registered User
ajg's Avatar
Default Re: Re: Re: Re: 70mph micro video?
Originally posted by GundamWZero
So what TC you had?
Why you stopped racing?
Where is your TC now?
TC3.
Track closed.
At home, in pieces.
ajg is offline
Old 08-16-2004, 04:04 PM
  #347
Trader Rating: 17 (100%+)
you won every time yet you dont know about cutting the com? you had to have your hobby shop do it? you cant direct solder, you use a futuba am radio with no adjustment. You must have raced some shitty ass people!
Kave is offline
Old 08-16-2004, 04:06 PM
  #348
ajg
Registered User
ajg's Avatar
No, those people could probably beat you.
Also, it doesn't matter what you have, it's how good you drive.
ajg is offline
Old 08-16-2004, 04:07 PM
  #349
Jack Smash's Avatar
Trader Rating: 34 (100%+)
Going down hill will allow an electric car to travel faster than it would on level ground. An electric motor has its greatest torque at the very bottom of its RPM range. An electric motor will never see its peak RPM in a loaded state for this reason. If you reduce the load (ie gravity pulling the car down a hill) the motor will be able to reach a higher RPM. You cannot use the maximum RPM of an unloaded electirc motor in your calculations for maximum speed in a vehicle, it simply doesn't have the torque to move the load at the higher RPMs.
Jack Smash is offline
Old 08-16-2004, 04:11 PM
  #350
ajg
Registered User
ajg's Avatar
Ok, my micro will go faster then. Too bad for you guys.
ajg is offline
Old 08-16-2004, 04:12 PM
  #351
how about you SHUT THE FACE AND PROVE IT! up untill now you have proven nothing
Kave is offline
Old 08-16-2004, 04:14 PM
  #352
ajg
Registered User
ajg's Avatar
Uh, sure mr. impatient. Wow, you've figured out that I haven't proved it yet? All by yourself?
ajg is offline
Old 08-16-2004, 05:33 PM
  #353
GundamWZero's Avatar
So AJG is gonna achieve 80 mph by going DOWNHILL? So, that makes him a cheater as well as a liar.
GundamWZero is offline
Old 08-16-2004, 05:37 PM
  #354
dracy69's Avatar
he isnt gonna make it to 80, not him. maybe some1 else
dracy69 is offline
Old 08-16-2004, 05:41 PM
  #355
ajg
Registered User
ajg's Avatar
Man, you guys are so lame. You know nothing about going fast, nothing!
Also, GundamWzero, your the liar.
ajg is offline
Old 08-16-2004, 05:43 PM
  #356
ajg
Registered User
ajg's Avatar
No one else has a micro with so much power.
ajg is offline
Old 08-16-2004, 05:55 PM
  #357
Nova F1 Racer's Avatar
Originally posted by ajg
You can't know its limitations without one, just like I don't know the limitations of your heli. Also, how is the car too small? And everything covers the same distance at 70mph. As for the motor, it has no problem moving the car, and when you add more weight with more cells, you get more volts too, so it's faster. Also, how are rc dragsters hitting 80+ mph in 132 feet. You don't need a velodrome!!!! Also, DaNieL_KuO, I'm not 15 years old.
Ok 16 years old then.....
Not impressed little man, not impressed....
Now, please go to bed, it's passed your bedtime.....
Nova F1 Racer is offline
Old 08-16-2004, 05:59 PM
  #358
ajg
Registered User
ajg's Avatar
Your not too impressive either. And I don't have a bedtime.
Also, your not rctech member #11, like you say in your sig.
ajg is offline
Old 08-16-2004, 06:40 PM
  #359
Dam, that looks like an 11 to me.......
And I'm arguing with a 16 year-old kid....
And please start staying awake during your English class, you might need it later in life....
And change your sig from garage to toybox little man.
1. futureal (2/20/04)
2. TSR6 (2/20/04)
3. petzl (2/20/04)
4. Peter Busch (2/20/04)
5. SpeediePHATT (2/20/04)
6. EddieO (2/20/04)
7. nashrcracer (2/20/04)
8. keithander (2/20/04)
9. f1junkie (2/20/04)
10. 17driver (2/20/04)
11. Nova F1 Racer (2/20/04)
12. ApexSpeed (2/20/04)
13. bainfowler (2/20/04)
14. John Fontaine (2/20/04)
Old 08-16-2004, 07:02 PM
  #360
ajg
Registered User
ajg's Avatar
Oh, 11th in posts, I think. Sorry.
Why change it to toybox? Is it because they're nicer than your cars in your "toybox"?
ajg is offline
