who holds the speed record? >
Old 08-12-2004, 09:29 PM
  #211
Let's continue firing up the hatred!!! Woohoo!!!!
071crazy is offline
Old 08-12-2004, 09:30 PM
  #212
ajg
Registered User
ajg's Avatar
I've spun the tires up to 96 mph, and they held up, so I'm not worried about tires.
I'll hook some up to my dremel though.
Also, I got a video of it. But I only ran it about half the distance I normally do. And I need to go up a few teeth on the pinion. I only hit 54 mph. But it was just the test run.
ajg is offline
Old 08-12-2004, 09:44 PM
  #213
ajg
Registered User
ajg's Avatar
Put it on my dremel and it did fine. On high and low modes.
ajg is offline
Old 08-12-2004, 09:48 PM
  #214
Let's see the video then......
071crazy is offline
Old 08-12-2004, 09:51 PM
  #215
ajg
Registered User
ajg's Avatar
It's not letting me upload it, so I'll have to shut down my computer and try again. It might be a while.
ajg is offline
Old 08-12-2004, 10:04 PM
  #216
razzo's Avatar
I know people are asking regarding tires, and response is' I've spun it up to xx mph'
but..... spinning a tire in air, is completely different than tire actually spinning at xx mph on SURFACE. There's that pesky laws of physics thing you heard about. How about friction and heat? You're spinning a tire with NO load on it. Throw the weight of the car on the tires, along with friction caused by the surface on the tires. I'd imagine a tire that small in diameter with that much load on it, spinning at 90mph would casue LOT of heat, which could casuse the foam to give out, or plastic rim from deforming. I bet TC foam tire/rim can hit 150mph spinning in air with out breaking up into pieces.
Good luck with your speed record run, but you seriously needed to pay more attention in physics class.
razzo is offline
Old 08-12-2004, 10:39 PM
  #217
ajg
Registered User
ajg's Avatar
Sorry, it's taken 40 minutes to upload the video and it wasn't even done. It was onlt 3 MB too. So I canceled it.
I'll get a new video tomorrow.
ajg is offline
Old 08-12-2004, 11:25 PM
  #218
Tim Johnson's Avatar
Originally posted by gotpez
As far as speed records being conducted on oval tracks, that is pretty much necessary for remote controlled vehicles. Since our transmitters have a limited distance they will work in, we can't just let them go in a straight line for a significant distance unless you have a chase vehicle. Not many of us have access to an area like the Salt Flats to do this. [/B]
Acualy and Offical IEDA landspeed track is 300 feet + a shutdown area. NOT an oval
Also the Soutwesttour group do insane speed runs at the encino veledrom. Infact August 28th will be a race there for oval, and im sure if enough people show they will do an insane class.
http://www.southwesttour.com/index.html
Tim Johnson is offline
Old 08-12-2004, 11:39 PM
  #219
GundamWZero's Avatar
I guess you guys aren't paying much attention........AJG already posted a claimed 70+ run, he want to go 80+...................
not possible, and I like to see him try.
GundamWZero is offline
Old 08-13-2004, 01:23 AM
  #220
DaNieL_KuO's Avatar
make sure ur video is less than 9 megabytes, one18th, wont allow any vids bigger than that thats why it wont upload right.at least since last year..I figured that problem out awhile ago...maybe now they wont even allow up to 3 megabytes?
DaNieL_KuO is offline
Old 08-13-2004, 01:26 AM
  #221
HA! Make it smaller than that so us with 28k dial-up atleast have a hope of d/ling it (3mbs sounds okay)
The Black Kat is offline
Old 08-13-2004, 01:34 AM
  #222
D/ling the 54mph vid right now....Can't wait to see it
I wanna see it when you gear up ..I hope you do know the Epic isn't made for over 6 cells. Unless you do some matinence its gonna be a somewhat wasted atempt (you do have a lathe..and brushes right?)
EDIT: Vid doesn't work...then again I'm on Windows 98....I don't count
Old 08-13-2004, 10:58 AM
  #223
Super Steve's Avatar
the video does not work...
Super Steve is offline
Old 08-13-2004, 11:06 AM
  #224
Cardboard's Avatar
Where did you get 54 mph from? that seriously does not look much faster than a stock touring car.
Cardboard is offline
Old 08-13-2004, 11:10 AM
  #225
Regional Moderator
UnderDaHill's Avatar
worked for me but I had to convert it in quicktime.
One word "tripod". That camera person had a bad case of the shakes.
UnderDaHill is offline
